PaceSetters Are On
Old Dec 8, 2003 | 06:39 PM
Farmer2's Avatar
Default PaceSetters Are On
They look great and the install wasnt that bad.
On the drivers side I opted to trim the stub sticking out at the back rear of the block with a sawzall. After that it slipped right into place. Passenger side was a breeze no probs.
The drivers side was hitting the k-member so I used a 1/4 in bit in a die grinder and made a 1/4 gap between them.
Before tightening the clamps for the Y-Pipe I pulled down a few times on the drivers side to give it more of a gap.
I highly reccomend putting Poly motor mounts in for sure and you wont have any hitting issues.
The Y-Pipe came with flat spots on the top for more clearance on the drivers side, it worked nice
I dont have any pics of them installed yet but I will get them somtime for yas
Old Dec 8, 2003 | 07:31 PM
Drew98TA's Avatar
We just got done installing mine a little less than an hour ago, everything went pretty smoothly execpt we had to do a little bit of grinding on the driver side b/c the header was rubbing. Only thing i need to fix is the y is banging a little where it is flattened... otherwise it was relatively easy. They look great too!
Old Dec 8, 2003 | 07:49 PM
onebadz's Avatar
Nice man, you should get them dynoed, cant wait till my headers.
Wes
Old Dec 8, 2003 | 07:52 PM
ss rally red's Avatar
Best bang for the buck out there in my opinion.
Old Dec 8, 2003 | 08:11 PM
CaMaRoHaTeR's Avatar
what kind of power do those make?
Old Dec 8, 2003 | 11:00 PM
02redSS's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/119846-pacesetter-install-dyno-track.html
Old Dec 9, 2003 | 09:16 AM
WS6FirebirdTA00's Avatar
yeah got mine in too, i have a bunch of pics too. definately do poly motor mounts, i have no knocking now. driver side header was ok jsut had to hit the firewall back a little bit with a hammer, then it slid right up
Old Dec 9, 2003 | 06:12 PM
93CobraPwr's Avatar
wheres the cheapest place to order the headers and Y?
Whats the going rate for the combo?
Old Dec 9, 2003 | 07:10 PM
Danny2tek's Avatar
TSP------------------------------------------------------------------->
Old Dec 9, 2003 | 08:23 PM
hell yeah, get the pacesetters and u will not regret it, i know a lot of people that got hookers that regret not gettin pacesetters
