Which one is more user friendly
And for all the people that say to '' try the search option" i have and i have not found the information i am needing.
Thanks
I also will avoid the 'which one is best debate'. So, I will only share my experience.
I picked EFILive software because I could also use the RoadRunner PCM with it. But this was just a personal decision not based on one software suite being better than the other.
I am very happy with the software I chose and tuning has become a hobby now. I will say the first 2-3 months does have a somewhat difficult learning curve. No matter which software you choose, the initial learning curve will be a challenge. You need a wideband and some open roads or a dyno to do all the VE Table and MAF calibrations. Then if you are wanting to keep it in closed-loop, you need to do some additional work on Fuel Trims, etc.
It takes patience, persistence and a mental ability to juggle multiple tables and parameters simultaneously. After about 4-6 months of trial and error, tuning became quite enjoyable.
Hope that helps. Both tuning suites will allow you to hit your goals.
Good luck in your decision.
..WeathermanShawn..
https://ls1tech.com/forums/pcm-diagn...-handheld.html
https://ls1tech.com/forums/pcm-diagnostics-tuning-7/
