ummm it won't fit
Old Dec 22, 2009 | 05:11 PM
SLICK_LS1's Avatar
Default ummm it won't fit
I bought a 85 maf. ANd i ordered the new SLP lid. But for some reason the maf is to big doesn't wanna go in . Never had this problem. DOes anyone know how to make it fit or do i need a reduction coupler. IF so where can i get one? Thanks- MIke
Sorry for the newb question
Old Dec 22, 2009 | 05:44 PM
jcobra99's Avatar
You will need a silicone coupler. Ebay has tons of them.
Old Dec 23, 2009 | 12:45 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Why the upgrade? Did you just want 85mm over 78mm?
Old Dec 23, 2009 | 04:11 PM
jcobra99's Avatar
You probably won't see any gains because the opening in your lid is now your "choke point" in your intake.
Old Dec 25, 2009 | 01:43 AM
chrs1313's Avatar
not true... the id of the lid is still bigger than 85mm and has no divider blade in the middle like a maf...
Old Dec 25, 2009 | 09:22 AM
Damian's Avatar
LSX Mechanic
I haven't seen any gains worth mentioning from a bigger MAF until you're north of 450+ rwhp. They don't do diddly **** until the MAF tables are scaled/smoothed/tuned by a competent tuner that actually works the MAF tables.
On a side note, SLP MAF's are total garbage and the designer should be repeatedly kicked in the nuts by every hardcore tuner on the planet.
Old Dec 25, 2009 | 12:01 PM
chrs1313's Avatar
agreed unless you are getting a tune dont waste your time
Old Dec 25, 2009 | 01:19 PM
1999BlueTA's Avatar
I agree but you will need a coupler to connect it to your current lid or upgrade to one of the bigger FTP/UTP lids I am running a delphi 85mm MAF with a regular MTI clear lid and the ID of the lid and the ID my 85mm MAF are almost the same size which is why I didn't upgrade to a bigger lid.
Old Dec 26, 2009 | 01:09 AM
chrs1313's Avatar
Originally Posted by 1999BlueTA
I agree but you will need a coupler to connect it to your current lid or upgrade one of the bigger FTP/UTP lids I am running a delphi 85mm MAF with a regular MTI clear lid and the ID of the lid and the ID my 85mm MAF are almost the same size which is why I didn't upgrade to a bigger lid.
yup just need a rubber connector for a couple bucks
