What type of OIL do you use???
It's all about the viscosity index. A perfect oil would be the same viscosity at every temp (and at least at this time is pretty much impossible). Ask the wind-turbine mfgs about that...
A straight SAE 30 oil has a poor viscosity index, at warm/operating temperatures it's perfectly fine (like in a lawn-mower that just sees spring/summer use), but at cold temps it would have a viscosity that is WAY too thick. That's why they added VI improver additives to make Multigrade oils.
The 0W30 GC has a similar VI as the 5W30 Mobile 1 IIRC. Although getting this info from the mfgs can be a pita sometimes...
Start adding moisture / fuel from blowby into the oil and it gets even more challenging.
And don't get too caught up on the "specialty" oil companies, I know people like to say it the best oil ever... but I'd trust Exxon/Shell/etc.. that spends more in R&D then some of the total sales of the smaller "specialty" oil companies anyday... Just saying.
Sometimes it's best to not tell your genius friends what you're running as everybody has un-educated opinions on "what's best" for you. OR try to make them feel stupid because you know more than they do.
When people say I’m nuts for using it, I ask them what additives their favorite oil has and at what temperature it breaks down. Often, these are the same idiots that use Fram Tough Guard filters or add conditioners like Lucas Oil Stabilizer which just foams up the oil with air bubbles. Brilliant!
Oil makers spend tons of money on their formulations so don’t ruin their carefully blended oils with any supplements or additives.
On your engine, you’ll be looking for the difference in cold start piston slap, valve train noise and oil consumption in the exhaust.
have you tried a 15-40w oil, i use this in my mother's lt1 camaro that has 125,xxx plus miles and it works great and in the winter i drop it down to accomodate for the cold weather, i see your in california so its pretty much warm all the time so you don't need to worry about the change of seasons
