TB bump stop mod?
Old Dec 22, 2003 | 09:46 PM
WS6FirebirdTA00's Avatar
Originally Posted by wrencher
There is a differerance between A-4's & M-6 cars.
M-6 start to spin they really spin.
true, didnt see that....
and u can get a volt meter and test it out, thats what i did. thats the safest way. before i ground some down just a little so it would open more but i wasnt even close to what i could be at. just get a volt meter, im sure advance has one u can use or something....
Old Dec 23, 2003 | 07:41 PM
ok here is the deal, when i floor it inside the car it doesnt open totally to the bump stop. how can i adjust this, or can i not adjust it?
Old Dec 24, 2003 | 08:10 PM
LS1 Sounds's Avatar
First off, make sure there isn't anything blocking your gas pedal from going all the way to the floor (such as a floor mat or trash). Not sure if there's an adjustment, that's a good question.
Old Dec 24, 2003 | 08:41 PM
everything was out of the way and there is an ajustment on the line and i found it. i posted somethign else about it. but thanks!
Old Dec 25, 2003 | 03:53 PM
unit213's Avatar
Administrator
MUST READ
Make sure to remove the slack in your throttle cable after doing this mod!
Old Dec 26, 2003 | 07:12 PM
jimmyblue's Avatar
Moderator
The best way to grind the stop tang is by measuring
the blade to 90 degrees open. Do this with a ruler,
keep going until you get the upper edge just to
the center of the mouth. Now you have minimum
airflow obstruction.
Then, if your TPS gives you too high a reading
(which it should not, if you didn't go over-the-
top mechanically, you can rat-tail-file the TPS
mount holes to make it adjustable.
http://community.webshots.com/album/56178226RrpzHw
