All F-Body TBs interchangeable?
Old Jan 20, 2010 | 07:53 PM
TeamLe's Avatar
Default All F-Body TBs interchangeable?
Can I use any year F-body TB on my 99 TA?
Old Jan 20, 2010 | 08:16 PM
03Sssnake's Avatar
Yep, pretty much the case. There 'may' have been a slight change in the TB/cam that opens the blade, not sure and someone should chime in..
Old Jan 20, 2010 | 09:03 PM
zracer323's Avatar
The tb cams are different on 98-99 cars than on 00-02. They swap pretty easy though.
Old Jan 21, 2010 | 06:53 AM
TeamLe's Avatar
Do I have to swap out the cam? Or will either work?
Old Jan 21, 2010 | 01:06 PM
MjMaro's Avatar
You will need to change the throttle cam, they are not ALL interchangeable, although within the years they are the same (98-99 and 00-02) they are able to be swapped with no modification. If you are trying to use a 98 TB on an 02 (or vice versa) then you will need to swap the throttle cam to get it to work properly.
Old Jan 23, 2010 | 10:26 PM
Bo White's Avatar
The 2004 GTO TB will go on a 00-02 Fbody as well.
Old Mar 6, 2010 | 01:27 PM
azibit's Avatar
Person Above NO it will not the blade that holds the cable is way smaller on a camaro than it is on a gto i tried it lol i ported an extra tb i had from my camaro and come to find out the damn thing didnt fit...
Old Mar 8, 2010 | 06:53 PM
george g's Avatar
I put a tb from an 01 camaro on my gto so they do work.
