Victor Jr or Super Victor in a F-body? Post up some pics installed
Old 03-03-2010, 09:43 AM
  #41
1CAMWNDR's Avatar
Originally Posted by bww3588
anyone else have any other options for an air cleaner with a 4150 TB other than the huge ricer looking tube with a cone filter?
Sure, cut an arch in the hood, cowl and windshield and put on a conventional 14" air filter that is 3-4" high. There is just not going to be much if anything else to do with this setup.
Old 03-03-2010, 12:05 PM
  #42
bww3588's Avatar
im diggin the 4150 TB, but not the look of the tube. i really hate to run it without an aircleaner....
Old 03-03-2010, 12:30 PM
  #43
bww3588's Avatar
https://ls1tech.com/forums/12670823-post6.html
i like this setup. looks the cleanest. the only other one i have seen is someone had one on a blue 4th gen that had like 6 feet of blue anodized tubing running from the 4150 down to where the battery would be.
Old 03-04-2010, 12:51 PM
  #44
studderin's Avatar
On the back of the Ebrock rails, what fitting are you guys using? I would like to run a 3/8to -6 stairt fitting, then a 90* swivel on the line. But worried there is room for that before hitting the firewall. If so do you have to run a 3/8 to -6 90* fitting in the back of the rails, and a stait swivel end on the line. That is a bit shorter of a setup.
Old 03-12-2010, 10:11 PM
  #45
ford's Avatar
Originally Posted by Goldfinger911
Installed on the car and on the mani while on the bench here:
http://www.cardomain.com/ride/2977048
Very nice setup. I have been thinking about going this route over a new FAST. What intake did you have prior to this setup?
Old 03-12-2010, 11:58 PM
  #46
Goldfinger911's Avatar
Sorry everyone for the late reply.
Prior to this I ran a FAST90 intake and TB. Ran great with my 383, however it sort of fell power wise off after 6000rpm. I ordered the elbow from Aaron and had him make one that was the least restriction as possible. Now, it revs easily past 7000 and has keeps pulling. Fuel mixture as well as Nitrous distribution for a wet shot is much better it seems with the Vic Jr. Plugs tell the tale.
Thanks guys.
Old 03-13-2010, 08:41 AM
  #47
niceguyyy01's Avatar
On the driver side, I run a 3/8"npt to -8 straight, then used a 90* hose end to clear the firewall.
Old 03-15-2010, 04:51 PM
  #48
99T/AVert's Avatar
Sub'ed
Old 04-01-2010, 10:39 AM
  #49
ryle's Avatar
Originally Posted by niceguyyy01
I'll have my super vic and 4150tb installed by the end of next week and will post pics. I have a 2000 WS6 with stock ram air hood. We'll see how it clears.
it's been a few weeks... how did the install go?? any Pics???
Old 04-05-2010, 08:03 PM
  #50
ryle's Avatar
Has anyone tried to fit a SuperVic, 4150 Tb and maybe a Spectre Carb hat under a stock WS6 hood? I am seriously thinking that it will work but would like to know if anyone has attempted it. My thought that it will fit is because 1CAMWNDR was able to fit the VicJr 4150 TB and a spectre carb hat under a stock flat hood. The SuperVic is only 1.17" taller so I was thinking it would fit under a WS6 hood with some cutting of the hood supports.
Old 04-06-2010, 01:30 PM
  #51
1CAMWNDR's Avatar
Originally Posted by ryle
Has anyone tried to fit a SuperVic, 4150 Tb and maybe a Spectre Carb hat under a stock WS6 hood? I am seriously thinking that it will work but would like to know if anyone has attempted it. My thought that it will fit is because 1CAMWNDR was able to fit the VicJr 4150 TB and a spectre carb hat under a stock flat hood. The SuperVic is only ~1" taller so I was thinking it would fit under a WS6 hood with some cutting of the hood supports.
The Super Victor has been measured to be a bit more than 1". Like 1 9/16" I think it was.
Old 04-06-2010, 02:50 PM
  #52
99T/AVert's Avatar
Not sure if I missed it or not but does anyone know if there will be a Super Vic for the L92 guys?
Also I am split between the "Cary's" (dont know the official name lol) and the Vic Jr. Except for the obvious benefits with the Cary intake and its 2 piece design, is there any other benefit over the Vic Jr to justify the cost? I am speaking unported by the way.
Old 04-06-2010, 05:31 PM
  #53
1CAMWNDR's Avatar
Even un ported the Performance Inductions manifold is better than a Victor Jr. The down sides are height, and price.
Old 04-06-2010, 06:22 PM
  #54
99T/AVert's Avatar
Well I guess it will be a Cary intake then. Thanks for the info!
Old 04-13-2010, 11:01 AM
  #55
StreetStalkerZ's Avatar
We used a spectre carb hat,2 spectre 45* elbows and a couple of 4" rubber clamps. Mine,his and another buddy have this setup on our cars.....the black carb hat will tend to flake the paint off.
Old 06-27-2011, 04:30 PM
  #56
Wildcobra's Avatar
Wow alot of good info
Quick Reply: Victor Jr or Super Victor in a F-body? Post up some pics installed
