Victor Jr or Super Victor in a F-body? Post up some pics installed
Old 01-28-2010, 11:44 AM
ryle's Avatar
Default Victor Jr or Super Victor in a F-body? Post up some pics installed
Like the title says.. I wanna see pics of both EFI and carburated setups with the Victor Jr or Super Victor intake. This style intake from what I have read is becoming more and more popular as an alternative to a FAST which IMO is severely overpriced!
I am seriously considering doing this, but won't really be able to make a decision until I see the setup.. I have heard that if you stay EFI the best way to go is with a 4150 throttle body rather than a elbow but I just don't know how well it will fit under my stock WS6 Hood. I am not opposed to cutting, as long as when it's all said and done it still looks the same on the outside.
Old 01-28-2010, 11:54 AM
frito1's Avatar
This is 1Hawk's car but he had a good picture under the hood for ya to see.
Two things to get full advantage of victor jr.
1. use the 4150 TB
2. use a cam suited for the short runner of the victor jr with a tight lsa (~110)
Attached Thumbnails Victor Jr or Super Victor in a F-body? Post up some pics installed-car.jpg   Victor Jr or Super Victor in a F-body? Post up some pics installed-car2.jpg
Old 01-28-2010, 11:55 AM
ryle's Avatar
what are the chances of running some sort of air cleaner for on the street?
Old 01-28-2010, 02:20 PM
LS1Tech Sponsor
Slowhawk's Avatar
Super Victor with a 105mm TB setup.Doubt I'll lose anything against a 4150 TB going by the flow of this thing.
The elbow/TB is 2.5" above the fenders.
Attached Thumbnails Victor Jr or Super Victor in a F-body? Post up some pics installed-011.jpg   Victor Jr or Super Victor in a F-body? Post up some pics installed-009.jpg
The following users liked this post:
Outlaw_Maro (08-06-2020)
Old 01-28-2010, 02:41 PM
1CAMWNDR's Avatar
I have some pics of my Vic Jr., Accufab 4150, Spectre Carb Hat and tube to the filter in the drag Racing section. Give a minute to find it and I will post the link.......
Old 01-28-2010, 02:45 PM
ryle's Avatar
I like the elbow.. Wonder if you could route that through this 104mm lid or this Volant CAI?
Old 01-28-2010, 02:47 PM
1CAMWNDR's Avatar
Forget the elbow. It has been proven in other posts that going from the elbow and 90mm TB to a 4150 4BBL is worth 50-60 rwhp.
Here is the thread with my pics:
https://ls1tech.com/forums/drag-raci...tock-hood.html
Old 01-28-2010, 02:51 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks like a Victor Junior. That setup wouldn't clear my hood with the Super Victor.
Old 01-28-2010, 02:54 PM
1CAMWNDR's Avatar
Yep it is a Jr. Would the Super not clear a WS6 hood?? I thought it was tall enough to make it work.....
I just need to put a decent size shaker scoop on there and run Cary's intake, and a 4500 TB .
Old 01-28-2010, 03:55 PM
ryle's Avatar
I'm not arguing, but what makes the 4150 with a carb hat better than a throttle body with an elbow.. either way you still are making a 90* turn.. I assume the 4150 TB straightens out the airflow just before it enters the intake??
Old 01-28-2010, 03:57 PM
LS1Tech Sponsor
Slowhawk's Avatar
Figure 1" to 1.5" higher which should clear but you have to pretty much cut out the whole hood support.I would figure the hat would be a big restriction too.
I wish the loss of 50-60hp was true.My 427 with a 242 Cam would be over 600rwhp with a 4150 TB.
Old 01-28-2010, 05:27 PM
1CAMWNDR's Avatar
The hp gain was listed in the dyno section a few months ago. I don't know how much the carb hat restricts flow, it is pretty big on the inside with a 4" opening, but I do know that the elbows cram the airflow to the back of the plenum. Might not be a big difference if you don't have the cam for a single plane....
Old 01-28-2010, 09:07 PM
98 4X4 burban's Avatar
Originally Posted by Slowhawk
Figure 1" to 1.5" higher .
i belive the SR. is 1.17 in taller than the JR. according to edelbrocks website.
Old 01-28-2010, 09:58 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'll play
Attached Thumbnails Victor Jr or Super Victor in a F-body? Post up some pics installed-100_1048.jpg
Tsc/98/TA (05-20-2020)
Old 01-28-2010, 10:58 PM
1sicws6's Avatar
do any of you guys have the factory abs with the victor jr?
Old 01-29-2010, 12:15 AM
outkast6991's Avatar
^^^^^look above you
Old 02-03-2010, 12:07 PM
Z28/2002's Avatar
The ABS is still there but doesn't work
Old 02-04-2010, 04:33 AM
Z28Caves60's Avatar
isnt running the abs as easy as putting a vaccum line to the rear runner on the victor jr.?
Old 02-04-2010, 06:48 AM
are you talking about the brake booster line? if so that isn't the abs
Old 02-04-2010, 11:45 AM
1CAMWNDR's Avatar
Yes, just the brake booster line. I don't see how changing intake manifolds would mess with the ABS.
Quick Reply: Victor Jr or Super Victor in a F-body? Post up some pics installed
