Poly Motor mounts on the way.
Old Dec 30, 2003 | 04:18 PM
SSactionLs1's Avatar
Default Poly Motor mounts on the way.
Now im 20, i like the cutout open, and i dont mind the cam lope..WIll this mod be too much to live with? I have a poly trany mount already and its no biggy to me..
please only post if u HAVE experience.
Old Dec 30, 2003 | 04:37 PM
felton316's Avatar
Poly mounts actually took alot of the shake out of my car. There is still vibration passed through the mounts, but it no longer feels like the engine is going to pop out of the hood. I installed both mounts (driver and passenger) and have the poly tranny mount.
Old Dec 30, 2003 | 05:37 PM
Mike K.'s Avatar
I think I may do this as well on my next build.
Old Dec 31, 2003 | 01:15 AM
onyxxtreme's Avatar
where can I get a set of the motor mounts?
ive tried a few sponsors to no luck
Old Dec 31, 2003 | 01:22 AM
fastsspr's Avatar
Thunderracing or Texas Speed and Performance they carry them!!!
Old Dec 31, 2003 | 01:59 AM
has anyone done them without taking the headers off? i would really prefer to do it that way.
Old Dec 31, 2003 | 03:45 PM
NEVR2ND's Avatar
I did it with Hooker LT headers in place. I had to drop the K-member about 2-3 in to be able to finish the install. It took about 6-8 hrs, and I only did the driver side mount.
Old Dec 31, 2003 | 06:04 PM
wtf took so long?
Old Dec 31, 2003 | 06:19 PM
NEVR2ND's Avatar
It is not as easy as it seams. The best time to do it is when you change your headers, or pull the engine out. If I had to do it again I wouldn't. Droping the K-member speeds it up, I was trying not to do it, so that's why it took longer.
Old Dec 31, 2003 | 08:02 PM
WILWAXU's Avatar
Related threads:
https://ls1tech.com/forums/generation-iii-external-engine/99615-poly-motor-mounts.html
https://ls1tech.com/forums/generation-iii-external-engine/116461-poly-motor-mounts.html
https://ls1tech.com/forums/generation-iii-external-engine/119357-poly-motor-mounts.html
Old Dec 31, 2003 | 08:25 PM
Jorday's Avatar
I know a guy that installed only the driver side when installing his headers. I couldn't even notice a difference when riding in the car.
Old Jan 1, 2004 | 04:40 AM
well then heres my next Q...what are the POSITIVES for this mod? like why am i gonna spend a whole day installing them?
Old Jan 2, 2004 | 02:24 AM
onyxxtreme's Avatar
motor doesnt twist in the chassis as much
helps header bang also
Old Jan 2, 2004 | 03:47 AM
well...yea...but WHY is what im asking..what does this help in racing/autoX/ cruizing?
Old Jan 2, 2004 | 04:02 AM
pekkaz's Avatar
Banging can cause false knock retard plus is annoying.
Old Jan 3, 2004 | 11:26 AM
ScottyG's Avatar
I had problems with the y-pipe banging the floor. The poly mount on the Drivers side only totally cured the problem, but didn't add hardly any more noise or vibration. It's a great mod.
We just put one on a friends car last night while installing Hooker LT's. I did mine a while back and removed the header, which wasn't too bad of a job.
The pass side is worse, and we didn't even want to screw with it last nigt, even on a lift with the header removed. Go for both if you must, but the drivers side only will probably do the trick.
Old Jan 3, 2004 | 02:05 PM
02 Silver Z's Avatar
Be forwarned, it`s not an easy install. (See my thread) I`ve done everything to my car mod wise myself including LT`s, converter, etc., etc. (As in no shop did any of the work.) And these have been a PITA! And I have the heads off the car so I can "get right at them"! Good luck!
Old Jan 3, 2004 | 06:56 PM
ive done everything myself too, but i dont see whats so difficult
Old Jan 4, 2004 | 11:37 AM
01ws6m6conv's Avatar
Getting at the bolts to remove and retighten and also fishing the stock mount out,and then fishing it back in . There is hardly any room for your hands or wrenches. Plus you get the poly mounts only. You have to drill out the rivets holding the metal clamshell together. Remove the rubber mount, then install the poly mount and rebolt the clamshell together. It is time consuming,but it was worth it to get rid of my flp y pipe from banging the floor.
Old Jan 4, 2004 | 04:32 PM
jerflash's Avatar
yo can someone send me a link to these on any sponser site
i cant find them anywere thanks
