Belt squeak...Crank pulley?
My belt is squeaking and I'm not sure why. Ive tightend the tentioner and the belt is not overly worn. It looks as if maybe the crank pulley is wobbling a little but not much. I'm thinking maybe thats it but how do i get it to spin without wobbling? The bolt is tight so Im afriad to tighten it any more. What should I do? Take it off and get a new bolt? Could it not be seated right or is it something worse? Should I be worried? Help
Well, it could be a lot of things. I don't think the crank pulley would be wobbling if you knew how that mother goes on and off. You won't be able to tighten the bolt any more, it should be at 240 ft/lbs which is VERY difficult to achieve, usually takes a large breaker bar, extension, and two people to get it even close to that. Spray your belt with some WD-40 and see if the noise goes away. It might be a bad idler pulley, when water gets in my engine bay, one of those pulleys starts to squeak really bad.
Originally Posted by 9T9BlueTA
You sure its not your AC belt?
I had a 98 Z28 before my WS.6, had the same problem. I took it in, it was under warranty, they fixed it. Mark Chevrolet said there was a bulletin on the cars because of the pulley system. They had to replace one of the pulleys, I can't remember if it was the tensioner pulley or not. Bulletins are GM dirty little secrets that nobody likes to talk about and they don't like to give out this information. That's the truth!!! Contact a dealership that will give you information so you know which pulley to replace. I went through hell tyring to solve the problem, one place said it was the alternator. Thus, I would of spent money on a new alternator all for nothing. Another place just said it was the belt and they replaced that, but that didn't work. Then heard about the bulletin. Pain in the ***
Originally Posted by SLP LS1
Good luck!
TSB 00-06-01-008 of MAR 00 states that:
"Cause: The serpentine belt squeak/chirp noise may be caused by misalignment between the idler pulley and the crankshaft pulley. A slight rocking motion of the idler pulley causes the misalignment, which results in noise."
"Correction: To correct this condition on vehicles built prior to the VIN breakpoint (VIN breakpoint Y2107225 with 5.7L V8 Engine) install the new generator bracket, double row idler pulley and serp. belt..."
"Important: This new generator bracket can be identified by the depth of the idler pulley mounting pilot. The pilot dimension on the new generator bracket is 10 mm. The previous bracket was 8.3 mm."
The new parts that you need are PN# 12563326 Double Row Idler Pulley Assembly, PN# 12563327 Generator Bracket, & PN# 12562626 Serpentine Belt.
I did this and still had the squeak. It was my AC belt lol.
is the ac belt only hooked up to the ac? the reason i ask is because my ac is blown and i have this belt noise that you all are talking about.
When i get up past 2,000 rpm the squeaking goes away, did anyone else have this problem?
idler pulley for the big serpentine belt it on the hmmm i think down on the driver side of the motor. its easy to see it has just a pully but does nothing and have a bolt through the middle of it, goes to no accessory or anything. try and start the car, popl the hood and hear where the noise is comming from. if u have a large extention put it on the ac tensioner and idler, and the serpentine tensioner and idler. well put it on the bolts in teh center. one of them u should hear a louder vibration through the extention and thats yoru problem pulley.
