ls1 oil changes...
Old May 18, 2010 | 06:30 PM
ramairfreak98ss's Avatar
Default ls1 oil changes...
So what is the best to use?
Synthetic of course.
What brand/model oil filter and how many quarts? anything special like you can add half a quart if swapping the filter out too etc?
Whats it take 5w30, 10w30? thanks
Old May 18, 2010 | 06:37 PM
omcar's Avatar
5w30 mobil1 nothing else..i use wix filters
Old May 18, 2010 | 07:04 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Agreed. I use Mobil1 5x30, WIX filter, however I use the bigger one. WIX 51522. Trust me, you'll see the difference.
Hold the one it calls for, then get the 51522 and put them next to each other. More filter is better and it wont trip into bypass mode so fast.
Old May 18, 2010 | 07:06 PM
joecar's Avatar
Mobil-1 0W40.
Old May 18, 2010 | 09:25 PM
conor.davis's Avatar
royal purple 5w-30.
Old May 19, 2010 | 01:16 PM
Siciliano15's Avatar
Mobil 1 5w-30. Next Oil change going to Amsoil Signature Series 0w-30
Old May 19, 2010 | 01:31 PM
PadenAlbin's Avatar
royal purple 5W-30.
Old May 19, 2010 | 01:44 PM
demarco313's Avatar
amsoil 0-30 or 5-30
Old May 19, 2010 | 01:57 PM
Bad Notch's Avatar
Non Synthetic cheapo 5W-30. I've picked up more HP non synthetic due to better ring seal. Also, oil in the intake has been drastically reduced.
Old May 19, 2010 | 02:07 PM
jester ls1's Avatar
Castrol Edge! Really does not matter just change your oil!!
Old May 20, 2010 | 04:28 PM
01'SSLSX's Avatar
this is the Exact same thing i use
Old May 20, 2010 | 05:01 PM
reds10406's Avatar
ditto
Old May 20, 2010 | 05:28 PM
jakes4321's Avatar
Brad Penn or Mobil 1
mobil 1 filter
Old May 20, 2010 | 05:59 PM
Roxas's Avatar
valvoline synthetic w/ a wix filter
Old May 20, 2010 | 10:31 PM
INMY01TA's Avatar
I've always used the German Castrol but may switch now to Castrol Edge or Penzoil Platinum soley cause Walley World sells the 5 qt jugs of these cheap. Ohh ya I use the Delco PF 61 filter I believe it is.
Old Jun 3, 2010 | 01:00 PM
venom 13's Avatar
Would cam and heads, matter much for which weight to use? (I'm going to do an oil change today and wondered about which weight to use in hot and humid southern Louisiana.
Old Jun 3, 2010 | 01:20 PM
majeskyb's Avatar
I use German Castrol 0w-30 when I can get it, or Royal Purple 10w-30. I also use K&N oil filters- I love the 1" nut on the end of it, letting me use a wrench instead of those crappy filter wrenches. The only thing "special", if you even want to call it that, is fill the filter with oil before installing it. Prevents the engine from running for a few seconds on no oil. Probably common knowledge, but you never know- I didn't when I first started changing my oil.
Old Jun 3, 2010 | 02:58 PM
pewter2002's Avatar
What ^^ said- "prime" the oil filter to avoid the oil starvation "knock" from an empty oil filter!
Old Jun 3, 2010 | 04:00 PM
MonmouthCtyLS7's Avatar
Your going to get a million different answers...Last change I used a Tough Guard fram filter (yes fram, but they seem to be alot better then the base filter) w/ Pennzoil Ultra...valvetrain has never been so quiet...
Old Jun 3, 2010 | 04:01 PM
Originally Posted by majeskyb
I use German Castrol 0w-30 when I can get it, or Royal Purple 10w-30. I also use K&N oil filters- I love the 1" nut on the end of it, letting me use a wrench instead of those crappy filter wrenches. .
Why do you need a filter wrench, its not like its hard to get to and spin it by hand.
