The fix for my endless alternator failure's
Removed alternator, noticed dirt line across alternator face, looked like brake dust, or brush dust should I say
Tested old alternator, passed bench test, failed diode test on car
Performed big 3, technically 4, upgrade, no.change
Swapped for another brand new duralast gold alternator, no change
Im starting to think I may need to go one size bigger on the belt. It seems like normal tension?
Also my 98 has a 2 wire alternator plug, what can I do to make sure the alternator exciter wire is good.
I can order a reman a.c. Delco, same price as my gold new alternator. Would that make any difference?
I sell alternators for Silverados all day and never get them returned. What's the deal with fbodies
This sucks, when the alternator gets hot it goes to high 12's and I believe is zapping power from the fans making it hotter under the hood. I'm just trying to daily drive old blue but the alternator combined with 107 degree heat makes my car go up to 200 or so in temps as the voltage drops
If you're exciter wire is acting up you'll get an L terminal code and a check engine light. I hunted that too for a while and it turned out to be the alternator every time. I even tried the big 3 and had no luck.
By the way, the ones I had fail, would test fine on a bench too. It's when they get super hot under the hood on a summer day that the voltage drops out, and you can't simulate that on a bench. I went round and round with the NAPA manager trying to explain this because they refused to give me a refund, they did eventually.
You're like me, you're checking everything testing everything and coming up with nothing, it all leads back to a crap alternator. I wen't through like 10 of them man, I was going crazy and chasing everything all the while, just **** alternators.
I have no problem swapping them, the a.c. Delco reman is the same price as my gold, I'll try that next since it will be a free trade
It's technically not failing, and the big 3 upgrade has definitely helped my radiator fans. 30 minutes idling with a.c. on and the needle was solid at 180
Just for fun
Just for fun
Keep doing everything but putting a quality alternator on it and you'll keep putting alternators on it.
You say it's not failing, yet it's not charging. Also, your factory alternator that was a quality unit never had a problem running the fans without the big 3, yet your big truck alternator needs help. All that sounds like a big pile of fail to me.
Why do a 105 when a 145 fits and works and keeps everything happier?
You'll get tired of ******* with it eventually and bite the bullet like I did. But feel free to come back and say you've got one that works great and then in 1-2 months post again that it took a **** lol. I've been there.
Did you ever try the Delco brand reman?
My original suspicion was that my car was the problem, as it's a swapped vehicle and i did a ton of wiring. However I began to think these alternators were the problem. With having a lifetime warranty on the autozone unit, I decided to try one more. Well f..k me, the 3rd one took a **** around the 150 mile mark, immediately following short throttle stab. I also discovered that it would charge until it started to get some heat into it. After hot it was dead, if let to cool it would charge again....
At that point, I started doing some reading. I came across this thread. Thank you to the OP for sharing your experience. I took the last alternator back to autozone and asked for a refund. The dude put it on the tester, brings it back and says "it's fine, you need to diagnose the car". After a lengthy discussion he did issue my refund.
I recently installed a 130 amp truck alternator in conjunction with Big 3. I don't have results yet but will update if it fails again. Just thought I'd add my experiences to this discussion.
So he's saying my options are junkyard oem or nothing.
Chrysler kid - I'm saying I tried everything you tried and the only thing that worked was a junkyard alternator, and in this thread you will find pages and pages of people using a junkyard alternator with zero issues. My OEM alternator did have a lot of voltage variation as well, the replacements held steady for a day or two until they bit the dust. My longest lasting alternator worked for 2 weeks then stopped charging when hot. That's the alternator that got me into an altercation with the NAPA manager when he wouldn't refund my money lol. I got the refund though.
To everyone - each unit would fail the first time I would make a pull, my rev limiter was at 6800 and not one of them took a 6800 rpm pull. The $40 junkyard alt took it EVERYDAY even with a system blaring and a/c running in 100 degree weather.
I now have a junkyard 145 amp on my truck because it came with the standard 105. I have added factory electric fans that pull around 40 amps and I have a real deal 2500 watt amp with OFC 0/1 gauge wiring pulling almost 150 amps and with all that the alternator is as happy as can be.
Nevertheless, I really appreciate you sharing your solution. I'd be ripping this car apart trying to figure this out. I just got the car back on the ground this evening after installing a 130 amp truck alternator and Big 3. Made 3 hard hits, did a few quick stab burnouts. The alternator held up fine.
That being said will this alternator work. Trying to find a southern alternator that isn't rusted on ebay
http://m.ebay.com/itm/ALTERNATOR-FIT...257Ciid%253A11
You have to go back to the basics here and evaluate the total situation. For the first probably 10 years of your cars life it never had charging problems, and the ONLY THING THAT CHANGED is you put a different alternator on it. Therefore, if you put another quality alternator on it the car will go back to doing what it previously did, working properly. We get caught up in making the problem more complex than it is and end up on bunny trails. I do it at work all the time, I go for the complex and forget to bring it back to a simplistic view.
That alternator will bolt up but it's a 2 wire instead of a 4 wire so you'll need to convert to the 2 wire connector end and google how to use a 2 wire alternator on a 4 wire car. I'd just get a 4 wire from a 99-04 and keep it simple.
I get my alternators from LKQ, I put a 145 amp on my truck recently, used from LKQ it was $60 and looked like ****. I cleaned it with a wire brush and drilled holes in the rear plastic cover to help with cooling. I even painted the pulley. All of this did just made it pretty, didn't help the output, but I work the **** out of this alternator and it has help up great.
Also I like the junkyard alternator not only because they work better, but they are only $60 and I can buy 3 for what 1 costs at autozone and they last longer. I can have a lifetime supply for $180 and if I fry one, no big deal it was $60 instead of $200 and having to exchange it all the damn time be stuck on the side of the road and argue with managers that won't warranty it because "it tested good on the bench"
I use a home alarm system battery to store the car to maintain the computer and electronics settings.. But disconnect the optima.. AGM batteries in general need a pulse charger on a timer more than a maintainer..
That being said, it's always a good idea to keep electronics cool and I agree especially with alternators, I drilled my rear plastic cover to allow for more cooling but I'm pushing my alternator way beyond what it should be pushed so I wanted to help it as much as possible.
There are several makes of cars with alternator cooling ducts out there, on some fords there is a duct that goes from the radiator cooling fan over and across the engine to the alternator.
But if you have a car that doesn't come with alternator cooling, the OEM alternator survived just fine and the only way an aftermarket will survive in the same environment is with cooling, then you are putting a band aid on the real problem.
When the 140amp alternator was attached to a 6 gauge negative ground to the case things got weird, the alternator would act like it wanted to kick into high output but would harshly dim the lights and buck the motor. My best guess is the trucks have a stronger ground on the mounting bracket, and a better ground to the frame than the fbody
The same new gold alternator works flawless in my truck, and the old 105 amp from the truck works flawless in the camaro
Out with the new
In with the old
And the new one in my base.model 2500 4x4 truck with crank windows
This **** is retarded
The parts store 140 amp max output cold peak voltage with a 6 gauge ground to the case peak output was 13.9 and dipped to 13.4 hot with a.c. on and lights on and was still dropping to 13.2. It was a .4 volt improvement from before but still a drastic drop
Truck used peak cold is 14.1 peak cold and 13.5 constant engine warm a.c. on. I'll perform an alternator test tomorrow but the used 105 amp shows no flickering check gauges light under WOT like the new one which would still show 12.9 at WOT but trigger check gauges.
A side note grounding the front bracket of the alternator triggered a much more drastic click from my relays, and a strong noise from my fuel pump and has cured my hard start issue
The old used truck alternator is more receptive to the exciter wire from the ecu. That's just how it is, not sure why
(I just swapped everything tonight and went on short drives each time, I'll test the 105amp used one from my truck tomorrow at my store to verify correct operation)
Picture of my old negative ground cable pulled when I did the big 3 upgrade, installed to the alternator bracket
