The fix for my endless alternator failure's
Old Apr 30, 2021 | 12:38 PM
  #1141
jybravo70's Avatar
Veteran: Navy
Has anyone looked at fabricating a bracket arm for the KG3's? How often do you check to see if any movement has occurred or are there torque requirements to get it snug so it doesn't move? As I am getting closer to throwing the stereo into my TA this will be an upcoming install.
Old May 1, 2021 | 02:46 AM
  #1142
sjsingle1's Avatar
bracket arm ??
Old May 1, 2021 | 10:37 AM
  #1143
jybravo70's Avatar
Veteran: Navy
Originally Posted by 00pooterSS
Yes the stock alternator has a small bolt at the top on the back side, its a pain in the a$$ to get to. Well that bolt goes through a bracket that mounts to the engine block right there with one bolt. So you remove the bracket and put in the truck alternator. The truck alternator does not use a rear support bolt and the case is larger so I think the bracket would end up in the way anyway, not sure didnt try putting the alt in with the bracket in since it was pointless being that the truck alternator does not have a bolt hole there. You just use the main two large/long bolts.
I would not recommend changing the stock one unless you have a problem with it, they are a much better product than the aftermarket ones. There may be a good aftermarket one if its custom built, but these off the shelf parts store one's are crap!
Post number 14 is where the bracket/arm question is coming from. Reading this is what concerned me at first as I don't know if the 2 bolts used can keep it from moving/rotating or slipping over time. As this thread has been going for years I was asking if anyone tried or needed additional hardware for mounting.
Old May 1, 2021 | 12:18 PM
  #1144
5.7stroker's Avatar
I've only been using 2 bolts and it's been fine.
Old May 3, 2021 | 10:46 AM
  #1145
00pooterSS's Avatar
Edit: i went back and re read your post. I'm gonna leave my original reply at the bottom and everything I typed.. I should have cut over half of this out because it repeats itself but I don't have time to edit it and make it short and easy lol.
Okay so on that bracket, there is no way to mount a bracket to the rear of a KG3. There is no hole back there on the kg3 to put a bolt in. The KG3 never used a rear support. It has always mounted the exact way you are putting it on your car.
The rear bracket IS NOT to keep the alternator from moving or slipping, it's a rear brace that isn't necessary. That's an old school thing that was needed for stamped steel brackets since stamped steel brackets would flex they needed a rear support. Best I can tell they transferred the support bracket over from previous generation technology and then realized they didn't need that bracket because it isn't used on any other LS or LT platform that I know of.
On ALL the trucks and other cars it only uses the two long bolts, same bolts that the f body car has, same size and everything.
There is no moving or coming loose that happens. The mounting pads on both alternators and bolt sizes are the same, that's why this is a direct swap. That and the plug plugs right in. This is a direct swap that uses all factory stuff that needs no modification. Because it is all oem, so it also lasts like oem fit does and doesn't cause issues.
The little L bracket is a F body alternator only thing. The F body alternator has a hole in the back of it for the bracket. The truck does not. This bracket was a design transfer thing that transferred over from 80's and 90's cars that used stamped steel brackets. They had to have a rear supports on them since the stamped steel brackets would flex and needed additional support. On those style they would brace the rear of the a/c compressor, alternator, ps pump everything. But as time went on with aluminum brackets they stopped using rear support brackets on most of those items.. None of the newer cars use the rear support on the alternator bracket either, or the trucks. And they're all fine.
There have been no long term issues mounting it the way laid out here in this post on F body cars. I made this post 11 years ago and not one single issue has been reported.
Old May 3, 2021 | 05:28 PM
  #1146
jybravo70's Avatar
Veteran: Navy
Thanks for the explanation, repetition helps with my addled brain. As always, thanks!
Old May 4, 2021 | 10:46 AM
  #1147
00pooterSS's Avatar
LOL no problem man. Best of luck hope the alternator helps you out
Old May 4, 2021 | 10:52 AM
  #1148
00pooterSS's Avatar
If it helps you feel more comfortable, and to further expand, we had a car come in one day, an early 4th gen car, believe it was a 93 and it made a weird humming noise with the a/c on. After a while of diag'ing the car we found that the rear support bracket was missing off the a/c compressor that steadied it. The noise was a vibration and the rear support bracket fixed the issue.
That's the only issue I have ever seen from not running the support brackets. But since that time the mounting brackets have become much more substantial in size and... beef. So the newer stiffer brackets seem to make it to where the rear brace is not necessary.
The 4th gen f body came out earlier than most of the LS platforms and used that bracket. The later LS platforms do not use it. I assume the c5 vette might, since it came out a year earlier than the f body. But in any case all the newer stuff does not use a support and the alternators do not even have a hole in them for it to be an option if you wanted it to.
I originally had concerns about not using that bracket but after a few years of running that alternator and this thread going on for years with no issues with my personal car or anyone else's, and seeing that gm went away from it, I'm going to say the bracket is unnecessary.
Old Jul 3, 2021 | 02:49 PM
  #1149
fucter's Avatar
My 2001 Camaro was charging the battery fine, but the voltage was fluctuating. So I replaced it with a KG3 - costs me $70 for a used one, but still cheaper than new. Ngl, it’s kind of a bitch to do, gotta bend both power steering lines out of the way.
I think for me the upgrade is worth it. The new alt is bigger and heavier fyi
Old Sep 12, 2021 | 07:03 PM
  #1150
ArcticZ28's Avatar
Anyone used this instead of the truck alternator?
https://www.hawksmotorsports.com/199...r-powermaster/
150 amp and it looks like it might have the mount for the rear bracket and third mounting bolt, though it's hard to tell without a picture of the rear.
I don't know what "One-Wire Capable:No" means, though.
Here's another one with 175 amp output and says it's "1-wire or OEM" and fits the LS1 98-02 generation.
https://www.tuffstuffperformance.com...us-8242nd.html
Old Sep 12, 2021 | 10:02 PM
  #1151
pdxmotorhead's Avatar
FWIW,, I bought AD244 "145 amp" from a local alternator shop, I had been having all kinds of weird charging issues on the old Delco one.. In the box with the new/reman alternator was a complete test sheet, including the power output.. the 140 amp mark was at a alternator rpm of like 4500, at 6000 it was putting out 170.. Its been rock solid so far, it runs at 13.8 V at cruise and 14.8 when on the throttle and for the first 5 minutes or so right after starting it up. I paid almost 200 for it cause my rig was down and I needed it back on the road.
FWIW if your looking for the AD244 they did come with 4Pin connectors on the mid 200 Vans it turned out. I bought a junkyard L59 to get all the external stuff to dress the L33 long block I put in my jeep (200 was way cheaper than chasing all the front brackets and ignition brackets etc down...
Old Sep 19, 2021 | 02:38 PM
  #1152
ArcticZ28's Avatar
I ended up going with a Powermaster 150 amp (https://www.summitracing.com/parts/PWM-4820) since I could get the upgraded amperage in the same GM CS130D casing style with the third bracket bolt. Bench testing card shows 114 @ idle, 150 @ "cruise", 185 @ "top end". Just installed it and will do some voltage testing in a bit.
Old Dec 6, 2021 | 12:44 PM
  #1153
winks79's Avatar
Just curious. Can I use a 145 amp KG3 out of a newer Chevy Express Van?? It is still listed as a KG3 in the 2012-13 model vans. Didn't know if anyone has info if they are the same alternator as the older versions. Will be doing this myself soon, as mine has not failed me yet, but does cause a lot of fluctuation in lights and dash. I do notice the voltmeter gauge dancing around a lot also.
Old Dec 27, 2021 | 03:57 PM
  #1154
winks79's Avatar
Ended up with a KG3 out of an 04' Tahoe with 80k miles. Works like a champ. Thanks so much for this thread 00pooterSS. Only had to tweak the power steering line just a bit, but got it in and cured my issues that was being caused by the original alternator.
Old Dec 28, 2021 | 08:50 PM
  #1155
chrisfrost's Avatar
Hello all the killer website for lots of used parts in all price ranges is "car-part.com" no s . You put in the year, make, model and the part Your looking for then the area where You live and most parts will bring up pages and pages of the part You searched for in a wide range of prices.
Old Feb 5, 2022 | 06:47 PM
  #1156
ws6-speed's Avatar
Just finished this on my 02 WS6.
I got a junk yard KG3 alternator from an 03 Silverado.
some observations…
1) take off all the bolts AND the alternator bracket. It’s so much easer just to take off the front alternator bracket. It’s only 1 more 15mm bolt and it’s easy to reach! I couldn’t get the alternator past the sway bar until I took the bracket out and then it was easy.
2) The 4 pin harness that has the exciter wire is a PITA to find. Unbolt the alternator and remove the bracket to give yourself some room to work…The image below shows the orientation of the alternator when it’s mounted in the car. The bottom is towards the ground.
the yellow square is where the 4 pin connector attaches. It inserts from the top down. The small blue shape is where the retaining clip is. You can use a short screwdriver from underneath the car to gently pry the retaining clip and the whole connector comes out super easy. Just insert the screwdriver from the bottom and pry the connector, lifting it towards the back of the car. Super easy once I figured it out…
3) The freaking battery charging cable is another PITA to get off. It’s mounted tight! When you try to loosen it, the lower nut spins as well. There’s a small plastic “stop” on the casing of the alternator. Turn the nut counterclockwise until the cable and ring terminal hit the stop, and then a sharp turn and the top nut comes right off! I couldn’t even get it off with an impact until I used the plastic “stop”, and then it came off with a 3/8” socket driver no problem.
4) If your PS pump is leaking a bit like mine (even after a rebuild…) consider making a shield for your alternator out of sheet metal. There’s room to do it (barely) and it’ll keep your alternator from being ruined again…I didn’t do it because it was so late and I was tired, but it could be an easy fix. I’m not looking forward to pulling the PS pump again…
Old Feb 6, 2022 | 12:51 PM
  #1157
BandDirector Blk98ZM6's Avatar
Any update? Mine just came in from Summit last week. Sitting on the dining room table waiting for me to install it!
https://www.summitracing.com/parts/p...saAnhMEALw_wcB
Old Feb 6, 2022 | 07:33 PM
  #1158
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Powermaster makes a great product, in my experience. I'm using a 10SI style version of their high output series on my '71 SBC car, I installed it back in 2012 and it's been nothing short of excellent. No signs of weakening or any issues after ~10 years. I know the CS130 is a different model but I've seen folks post great results from this Powermaster version over the years as well. This is what I would purchase for an LS1 car if I needed one.
Old Feb 7, 2022 | 04:26 PM
  #1159
RB04Av's Avatar
Stop sitting on the table and move it to your back seat floorboard. Still "improperly installed", but closer.
Old Feb 7, 2022 | 08:01 PM
  #1160
Might forget about it there and never install it 🤫. As long as it’s in my way when I eat, and l like to eat, then I’ll install it sooner to get it out of my way 🤦‍♂️😁
