The fix for my endless alternator failure's
Also, before you start working on it make sure you have a nut for the terminal, I figured they were the same and I was wrong, so I had to dig around and find one.
You don't use the rear mounting point (13mm bolt), right?
Most of them came with an "oval" piggyback on the car, but some have a square one and they don't stock the square connector cause very few used it.
Just something to watch out for.
Kyle
Might look to do the "Big 3" upgrade though the "sticky" has lost all it's pictures
I do have a small issue though, I am having belt squeal issues, even after replacing the belt, the alignment seems to be a hair off at the the alternator to idler pulley to crank pulley area, anyone else having any issues? I did change the idler pulley at the same time so it could be that pulley, but I lost the factory original so I cannot test that theory, if someone had one even with a bad bearing I would be interested in it.
I used a stethoscope and the squeal is coming from where the belt enters the crank pulley, so all this gathered info tells me the belt is a bit forward where it enters back onto the crank pulley. So either the Alternator pushed the belt forward and it now rides closer to the front of the idler pulley, or the idler pulley does not stick out as far and the belt runs on the rounded nose pushing the belt forward. I don't have either one of the original parts (alt or idler) to test this though
