LPP True Duals
Old Jun 20, 2010 | 11:21 AM
JohnnyBz28's Avatar
Default LPP True Duals
Finally got my LPP True Duals on
Old Jun 20, 2010 | 11:34 AM
hawiianpwr's Avatar
That setup is sweet! Sits so damn low though.
Old Jun 20, 2010 | 11:35 AM
JohnnyBz28's Avatar
Yeah I ordered Global West 1.5" spring spacers to raise the rear 1.5". Hopefully that's enough so that I don't scrape on slight bumps lol
Old Jun 20, 2010 | 07:14 PM
fuel's Avatar
sound real good....sounds like a corsa
Old Jun 20, 2010 | 07:27 PM
Jimmy P's Avatar
How would you say they compare to true duals with two actual bullet mufflers? Are these louder?
Old Jun 20, 2010 | 07:49 PM
JohnnyBz28's Avatar
I'll find out when my friend gets his car. His car has the TSP true duals.
Old Jun 20, 2010 | 08:38 PM
RrCoX22's Avatar
im sure it's pretty damn loud since there's no baffling at even from a resonator or bullet...
Old Jun 20, 2010 | 08:41 PM
TImmy_Jones's Avatar
wOW! awesome man. Have any side shots? How low do they hang?
Jimmy P's Avatar
The pieces before the tips are the resonators. They are built in.
Old Jun 20, 2010 | 09:43 PM
JohnnyBz28's Avatar
The turn downs have a resonator welded into them It's actually not that loud. Check the video's I have posted out
Yeah it hangs pretty low because I'm lowered. I ordered some global west 1.5" spring spacers that will raise the rear 1.5". Once I have them in I'll retake the side shots. Here are some for now:
Old Jun 20, 2010 | 11:20 PM
Oh damn! That is low...thought my 1 soda can clearance was bad on my 3" Y. Hope you get the car up a bit higher, would hate to see such a nice setup ruined. Is it unbearable loud? Especially dumped under the car?
Old Jun 21, 2010 | 01:39 AM
gearhead1186's Avatar
hope those spacers work. cant wait to hear it in person!!
Old Jun 21, 2010 | 01:57 AM
kobraa's Avatar
Old Jun 21, 2010 | 06:39 AM
JohnnyBz28's Avatar
Listen to the video, it's not that loud.
They should work. I barely scrape with myself (155lbs) and my friend (210lbs) or father (200lbs) in the car when I drive most places. The only time it really scrapes is when its a dip otherwise it's fine.
Originally Posted by kobraa
use an image that makes sense for everyone else
Old Jun 21, 2010 | 11:35 AM
i guess the stiffer springs help it out.
Old Jun 21, 2010 | 12:09 PM
ShamelessCookie's Avatar
Which longtubes do you have?
Old Jun 21, 2010 | 12:46 PM
JohnnyBz28's Avatar
Older style LPP's. Really wish I had the cash to either get the new style LPP's or ARH's
Old Jun 21, 2010 | 12:50 PM
deelong4002's Avatar
Damn those are low. My TSP setup has to have twice as much clearance if not more, and it has bullets.
Of course i am at stock ride height too so obviously that helps
Old Jun 21, 2010 | 12:57 PM
sscamaroburn02's Avatar
wow that is low i hope mine aren't that bad after i'm lowered
Old Jun 21, 2010 | 01:00 PM
JohnnyBz28's Avatar
Yeah hopefully the spacers I ordered will work. What springs are you looking at sscamaroburn02?
