Fast toys ramair installed...
Old 07-06-2010, 12:48 PM
Lotapwr's Avatar
Default Fast toys ramair installed...
After some research on ls1tech I decided to spring for the FTRA. Installation took me about 3 hours(workin alone), but fits great and very steath. As far as performance gains, picked up 1 thenth and 1 MPH at Raceway park 1/4 mile. SOP feel is very noticable, I thought it would be more than 1 tenth, but still happy with.
Old best: 13.08 @108.
New Best: 12.96 @109.
Old 07-06-2010, 01:15 PM
sscamaroburn02's Avatar
1 tenth is not bad for a mod like that. i would bet if you had a cam and heads if would have been more helpful.
Old 07-06-2010, 01:26 PM
Ls1Rook's Avatar
What was your DA in the runs?
Nice gain.
Old 07-06-2010, 01:36 PM
Lotapwr's Avatar
still a little new at this, what does DA mean?
Old 07-06-2010, 02:13 PM
ULTIMATEORANGESS's Avatar
get a stall next. youll be very happy.
Old 07-06-2010, 03:28 PM
w3s1c0a5t's Avatar
Did you seal up the intake path good?
Old 07-06-2010, 04:24 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Density altitude - it takes into account a few variables, and gives you an equivalent altitude. This is usually important to people involved with aviation, but it also helps to know it when you run down the quarter mile. If you are running in shitty air (say 90*, humid as f***), the DA will reflect that (the DA will be a higher number) so you can take that into account. If you end up running again with awesome air (like 40-50*, low humidity), the DA will be lower - people often record their fastest runs with negative DA values. Bottom line: it helps you compare apples to apples if you have your e.t. and trap speed along with the DA for your runs.
Good question - the seals provided with the FTRA kit are adequate at best. You might not see much better results by going to all of the effort to seal it perfectly, but it probably wouldn't hurt. To get an idea, just take a leaf blower and aim it up the scoop - feel around the lid and the lower air box assembly for any leaking air. You might be surprised at what you find.
Old 07-06-2010, 05:41 PM
Ls1Rook's Avatar
http://www.dragtimes.com/da-density-...ect+ET+and+MPH
Old 07-06-2010, 09:19 PM
Lotapwr's Avatar
Thanks for the advice, i'll check the airbox for any leaks.
Old 07-06-2010, 09:24 PM
MYSTIC-1SC's Avatar
nice gains.
Old 07-06-2010, 09:36 PM
pharmd's Avatar
Good call...I gotta try this on mine. We used a flashlight, but a blower would be good too.
Old 07-07-2010, 02:29 AM
KTK Z28's Avatar
How did the FTRA fit? I have the Chris1313 (ac version) and was very disappointed with how it fit. I had to modify it extensively to get it to fit, and even now it doesn't fit THAT great.
Old 07-07-2010, 04:31 PM
chrs1313's Avatar
shoot me some pics...yes it will be very very tight...it is max effort for keeping the ac...I have never had a problem with the 5+ intakes I have installed with ac...
did you bend the ribs under the radiator support flush forward...that alone allows for a 1/2 or more clearance...shoot me a pm and we can work through this...
Old 07-07-2010, 07:55 PM
KTK Z28's Avatar
Hey chris i will definitely PM you later tonight. I didn't want it to seem like I was bashing your product so i didn't go into detail in this particular thread.
Yes I did bend the lip under the radiator support forward. Thanks
Old 07-08-2010, 02:09 AM
Lotapwr's Avatar
Hey KTK, It fit almost perfectly, but it took some pushing and pulling to get the bottom three bolts that connect to the bottom air dam to connect. other than that the install went smooth.
