Misfire, rough running after rain
The other night it rained hard while we were out, and it started ******* and missing. part-to-WOT seemed to get it to run, but then it would start missing again. A couple of days later, still missing. We haven't driven it in the rain before (had the car for a month now). I read a post that said the AIR check valves can cause some of that, and then another that said pull the O2 sensor plugs and put dielectric grease in them, that they dry out and get water in them.
I've now pulled the AIR system, plugged the vacuum, pulled one o2 connector and greased it, other side looked high and dry (they used an extension cable with plugs on one side, and spliced cable on the other side and taped up that side well. I then changed the plug wires, put in Belden premium wires, fixed a cracked pcv hose...
Fired it up... grrr. Same thing. cleared and read codes, cyl 6 misfire. So I think I might move the coil pack and see if it changes to another cyl. I think cyl 6 is one of the tough ones to get to on the pass side?
Anyone have any other ideas on troubleshooting this? Open to suggestions. I'm going to try to get some o2 sensors soon, maybe that's all it is.
Oh and I did clean the MAF very carefully a while back, no noticeable difference. Car was not missing like this before the rain, but the rain was last Thursday.
all very frustrating... At least I managed to get all the wires changed out, and I'm getting where I'm feeling comfortable messing with this engine. It's bigger and newer than any I've worked with before.
have you checked the plug on #6? its always possible to have one that took a **** on ya..
its been like this sense May and im dying to fix the problem
I swapped coil packs #6 <-> #2, and got the scan tool working again with the help of ObdPros support. Cyl #6 misfire, still. SO... it's not the coil pack. Time to (gulp) change those plugs. Mind you, my hands hurt already....
Ok so 1, 2, 5, and 7 were easy. 2, not so bad. 4 was terrible to get to - took about an hour before I figured out the right combination of extensions and wrench. Previous plugs were NGK TR55G-something. Then I pulled #6. holy cow. gap was about .060, and I was very careful pulling it out. And it was an AC Delco. Considering that when I changed the spark plugs I found one boot was barely touching the plug, the oil dipstick bracket bolt was loose about 1/4", the header bolt above plug #4 still had an 11mm socket on it, and a 15mm bolt above #6 was backed out about 3/8".... I'm not too surprised at the #6 plug.
So I put new NGK TR5 V power plugs back in. All I have is LTs, oh and I have braided brake lines I discovered - cool huh? -anyway so I think until I swap cams I should be ok without the TR55 or higher temp plugs.
I got it back together, cleared the trouble codes, started her up, and it sounded much better. I let it warm up, backed it down the drive, and as I got to the main street, it started bogging down.
Well as we were driving, we had the OBD_DIAG tool reading PIDs, and noticed some interesting numbers on the O2 sensors (keep in mind we have 2 sims instead of rear sensors):
Bank 1 Sensor 1 - seemed to fluctuate normally, got up to .900 or so.
Bank 1 Sensor 2 - stayed around .445-.450
Bank 2 Sensor 1 - stayed at a constant 1.105
Bank 2 Sensor 2 - fluctuated a little, around .445 I think.
So... looks to me like passenger side o2 sensor is toast. Good thing I have two of them on the way now, UPS ground. I'll update again when I get them installed...
This is just speculation, maybe someone can verify... but it would explain my issue and also jb98camaro's issue too... I had a cyl 6 plug that likely wasn't firing. So prob that means unburnt fuel was hitting the sensor. Also I don't think the car was tuned after putting long-tube headers and off-road Y + new exhaust. From some reading last night, it sounds like that kind of thing can foul your o2 sensors. Also I was reading that they have internal sensors to detect O2 in the exhaust flow, and external (outside the pipes) to detect atmosphere O2 levels. If that gets wet, maybe it can mess them up? I dunno, seems it would be so hot that water could not affect it, and they are so close to the ground... although I think on mine they are much farther back than stock, hence closer to the ground than intended?? Anyway, I am pretty certain that the reading on my B2S1 sensor of constant 1.105v indicates it's toast. I think it is telling the engine to inject more fuel... if I understood what I was reading? There's a diagnostic manual which indicated values are 10 - 1000mv where higher numbers indicate more fuel needed. If so, then 1105 is off the charts and it's dumping gas like crazy. Explains the heavy gas smell it's giving off now. Also explains why it's missing so bad.
Up to about 3500-4000 rpm it's ******* badly, then it will surge and run normal. I think that's where it is no longer closed loop (i.e. O2 involved in fuel calculations), which also makes me pretty certain it's the sensors.
Same thing my GTO was doing. I also ordered new O2 sensers and while I'm at it added 42 lb. injectors, sending the PCM off in the morning to get tuned and we'll see what it does then. Definitely keep us updated Milburnr. Weird how it happened but as soon as I get my stuff back I'll let you know . Subscribed
https://ls1tech.com/forums/new-ls1-o...r-run-bad.html
Went and started it and it's running much smoother! Not 100%... but we looked at the codes and the PIDs for the engine, and it seems that Bank 2 Sensor 1 is not giving a signal. Or at least the signal is not being read. It is sitting at .435-.450v for that sensor, while bank 1 sensor 1 varies from .030 to .950. So there must be a wiring issue, which I will trace down tomorrow somehow. I do have a multimeter after all
In any case, it's not running very rich at all, and it's driving pretty good. Doesn't seem to be missing.
I put both sensors in. However... when checking the wires for the passenger-side sensor, I inadvertantly mashed the metal pieces inside the connector (doh!). When the sensor wasn't registering, I removed and and found the problem. I found (hope this isn't a plug) the connector parts at Napa, no other local auto parts have them. Once I fixed the plug, and reinstalled the sensor, it was responding normally... and the problem seems resolved.
I did cut about 12" out of the extension wire, it only needed to be about 18" and it was much longer than that. I don't know if that mattered at all.
I haven't tried to get the car wet, and rain is not in the forecast. But hopefully this fixed the problem. I sealed the wires up tight with electrical tape.
