question about throttle bump stop mod
Old Feb 1, 2004 | 06:02 PM
Turo's Avatar
Default question about throttle bump stop mod
so i havent done the bup stop mod yet, but i checked the TP value woth efilive for my car, and at full throttle it marks 100%, but when u look at the throttle body you can tell its not opened up all the way. if i do the mod, will it set a SES light?
Old Feb 1, 2004 | 06:06 PM
unit213's Avatar
Administrator
It will only throw a code if you go over 4.7vdc. I'm not familiar with EFILive so no help there unfortunately.
Old Feb 1, 2004 | 06:09 PM
wrencher's Avatar
wrencher
Look at this it is a good write up on the subject;
www.ls1camaro.net/sections.php?op=viewarticle&artid=26
Old Feb 1, 2004 | 06:21 PM
Turo's Avatar
well, i guess ill just measure the voltage then, instead of going by efilive. thanks for the help
Old Feb 1, 2004 | 09:58 PM
Orange Juice's Avatar
I would think that you could file the holes on the throttle position sensor and retard the tps if you did throw a code
Old Feb 1, 2004 | 10:31 PM
wrencher's Avatar
wrencher
It does make it easier to make TPS adjustable.
Old Feb 1, 2004 | 11:03 PM
jimmyblue's Avatar
Moderator
http://community.webshots.com/album/56178226RrpzHw
Old Feb 2, 2004 | 05:37 AM
pimpmaro's Avatar
EFI Live has TPS Position and TPS Voltage. The position always learns itself to 100%... the voltage is what you're lookin for. My stock voltage was 4.3 and I ground down to 4.6. The PCM always figures out what 100% throttle is. Good luck.
Old Feb 2, 2004 | 08:51 AM
Turo's Avatar
ahh, ok theres my mistake then, i was going with position, not voltage (i didint know it learned itself to 100%). thanks for all the help/links, guys!
