Exhaust, intake, headers tune
Old 11-04-2010, 01:50 AM
01transampower's Avatar
Default Exhaust, intake, headers tune
I own a 2001 WS-6 trans-am with only 35 thousand miles. Its bone stock and i want to open it up a little bit. I plan on putting an slp air intake on it. shorty headers and a full true 2 1/2 inch dule exhaust. then getting a tune on it to get it all put together and mapped only on 91 octane. Does anyone have a rough idea on a horse power rating id pull with all this? I also live in colorado so this is a factor as well.
Old 11-04-2010, 02:12 AM
cadenwade's Avatar
auto or m6
Old 11-04-2010, 05:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
This is the internal section. I will move it to the External for you, but just be conscious of where you post. I noticed you were new.
Welcome!
Old 11-04-2010, 05:24 AM
davidws6's Avatar
Go long tubes on the headers. A lil more $ but u'll gain more hp n tq.
Old 11-04-2010, 11:57 AM
yea sorry i am new trying to work it out. Thanks you. It is an m6.
Old 11-04-2010, 12:00 PM
Element's Avatar
With an '01, going to shorty headers is going to be a very minimal power gain. If you can't go with LTs due to emissions/inspection, I'd just leave the manifolds alone and spend the money somewhere else.
Old 11-04-2010, 12:01 PM
with the long tubes do i need to get high flow cats? because in colorado im required to have cats and i really dont want to deal with putting stock stuff back in every couple years.
Old 11-04-2010, 01:41 PM
SShawn's Avatar
If you need them for inspection save yourself the hassle and just buy a catted set.The power difference isnt that significant unless you have certain goals in mind, but for a daily driver or weekend cruiser why cause extra headaches? Give us a call or email if you would like any other guidance or help.
Old 11-04-2010, 01:42 PM
SShawn's Avatar
oh and you'll definitely want longtubes unless you absolutely need to have shorties for emissions concerns.
Old 11-04-2010, 02:08 PM
Element's Avatar
Longtubes are still "illegal" because they move the cats. If it's an easy visual and they're not going to bitch about the cats not being in the stock location, you'd be fine with a catted setup. If it's an OBD2 scan deal, you can have the rear O2s tuned out and, as far as I know, it shouldn't cause any problems with a scanner test.
Old 11-04-2010, 02:31 PM
thegodfather899's Avatar
Agreed go with LTs
Old 11-04-2010, 07:33 PM
When i get emissions they do not visually look at the cats. They are just need when they hook the sensors up. So with an SLP intake, K&n air filter, long tube headers, dual 2 1/2 inch exhaust and a tune what are possible numbers i could put out?
Old 11-04-2010, 08:03 PM
TheBlueKnight's Avatar
Your going to put down somewhere around 335-345rwhp or around 400ish at the motor.
Old 11-05-2010, 12:05 AM
Thank you!
Old 11-06-2010, 10:21 PM
IWGF's Avatar
Get longtubes, ditch the cats, get a tune, and they'll delete your o2 codes for the cats. You'll be fine.
Old 11-06-2010, 10:22 PM
IWGF's Avatar
Not in Colorado bub... OP, what's your elevation? I'm at 5800 above sealevel, altitude rapes N/A cars.
Old 11-07-2010, 04:01 PM
That's corrected hp bub. I have 340rwhp corrected, but where I live I'm at 4,000ft. I only make 300rwhp here.
Old 11-07-2010, 06:36 PM
IWGF's Avatar
Touche salesman
