looking for good p/n and supplier for ls1 idler pulley
Old 11-04-2010, 01:36 PM
dc8fixer's Avatar
Default looking for good p/n and supplier for ls1 idler pulley
I am trying to find a good p/n or source for my drive belt idler pulley for the alternator,water pump,power steer. Not the grooved tensioner pulley the smooth pulley(3 inch dia. 1.125 inch wide). I have tried a ac delco supplier they gave me a acd#38006,gm#88909587. Plus o'reilly's gave me a gates #38006. Both of them are different than my factory pulley. The mounting bolt and washer hit the front face of the pulley(the recess is different). Autozone and Napa didn't have it in stock and I hate to order it and have the same problem. I called the dealer and they have to order it and its $69. Its a 1999 Z28.
Old 11-04-2010, 03:24 PM
sjsingle1's Avatar
there is a difference in idler pulley styles.....there was a TSB in 2000 about it.....2000 and up used a different bracket and pulley.....you have to match the bracket with the right pulley.....no mix n match.......the new style pulley is either dealer or special order from dayco....seeing as how you have the older 1....its a stocking part at most stores....unless someone changed the bracket and pulley out on you in the past....dealer was 60$.....the dayco was 45$
Old 11-05-2010, 12:36 AM
01ssreda4's Avatar
What pulley are we talking about here. Someone got a pic?
Old 11-05-2010, 03:49 PM
sjsingle1's Avatar
bracket and pulley
Old 11-05-2010, 03:54 PM
sjsingle1's Avatar
if you put the old style pulley on the new bracket it hits the bracket and will not turn.....ask me how i know
Old 11-05-2010, 04:18 PM
MM98's Avatar
Try gm# 12564401.
Old 11-05-2010, 05:12 PM
sjsingle1's Avatar
the bracket is 12563327.....pulley 12563326
Old 04-28-2011, 11:44 PM
forcerecon's Avatar
i have a 98 z/28 with squealing idler pulley.replaced it today with dayco 89159.the front and back washers do not come with the dayco.i was told by parts people you dont need them with the dayco,just run the bolt through.well it squealed worse than ever and pulley was super hot.anyone have similar experience?taking it back tomorrow and ordering ac delco gm12564401 from gm parts direct.hope it's the same as oringinal
Old 10-05-2011, 09:31 AM
samckitt's Avatar
Reviving an old thread.
I went to the dealer today to get part number 12564401. It was in stock & the guy went back to get it. I didn't buy it for 2 reasons. 1. it was right at $70, and 2. The hole through the bearing was about .5" dia and the bolt dia was about 5/15" dia. Way too much play between the bolt & the bearing & the washers that came with it didn't line anything up either. Didn't look right to me.
Old 10-05-2011, 04:18 PM
LS1MCSS's Avatar
There is a spacer that goes betweem the pulley and bracket that also takes up the difference between the bolt size and bearing ID. I can make you one if you get me the correct measurements.
Quick Reply: looking for good p/n and supplier for ls1 idler pulley
