SLP Y-pipe ?'s
Old Feb 2, 2004 | 07:19 PM
02WS6Bird's Avatar
Default SLP Y-pipe ?'s
those of you with the SLP Y-pipe....how far does yours hang down.....and how much farther does it hang then the stock "flat" y-pipe
Old Feb 2, 2004 | 07:20 PM
02WS6Bird's Avatar
any picturs of yours will be helpful
Old Feb 2, 2004 | 08:33 PM
SSTYCOON's Avatar
I don't know exactly how far the SLP y pipe hangs down, but i do know it's more visable than the stock y from a side view.
Old Feb 2, 2004 | 08:38 PM
02WS6Bird's Avatar
anybody else....the stock ones pretty flat right? like not nearly as noticable as the SLP Y-Pipe
Old Feb 3, 2004 | 08:26 AM
jimmyblue's Avatar
Moderator
Yes, you can see it from the side. To tuck it up tight
you will probably have to "dimple" a spot or two.
Expect additional effort on a convertible (to put it
mildly).
http://community.webshots.com/album/42267828Hxlyau
Old Feb 3, 2004 | 12:30 PM
demonspeed's Avatar
It's not mine! woo hoo!
It does hang down a bit more than the factory flat one, but it's really not bad at all. My car isn't lowered yet, so I don't know how much that'll effect it.
OTOH, it's not as low as long tubes. It also is probably just as low as a set of subframe connectors.
Another thing... do you really want to spend the money on it? I don't think the gains are much if anything. I got mine because I bought it used from a friend.
Old Feb 3, 2004 | 12:43 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I had the SLP catted Y running off SLP LT's. The driver's side part of the Y scraped every so often on speedbumps and street/sidewalk curbs.
Old Feb 3, 2004 | 05:18 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
SLP Y-pipe for stock manifolds gave me 3.25" ground clearance on the driver's side on my stock ride height car. Stock Y-pipe gives 4.25" clearance on the same side.
The Bassani Y pipe I have now (for the Bassani headers) gives the same 3.25" as the SLP did, but it looks lower because it swings out farther towards the edge of the driver's floor pan. Most header pacakge Y-pipes look a lot lower than the stock Y because they swing out farther. However many don't hang anymore than 1-1.5" lower than stock, making them only an issue if you plan to lower your car.
Old Feb 3, 2004 | 05:27 PM
02WS6Bird's Avatar
thanks i already have the SLP Y-pipe...bcuz it does deapon the LM sound a little bit...i was just wondering if that was normal for it to hang that low
thank you guys
