Best Catch Can??
Old Nov 8, 2010 | 09:07 AM
vatechguy3's Avatar
Default Best Catch Can??
Looking into installing a catch can on my car (see mods in signature)
considering the following:
RX Performance LS1 Single Catch Can
Saikoumichi LS1 Dual Can
Which one would be best and why?
Any other opinions on different models which work better?
I use the car for autoxing, drag racing and hopefully some track days soon. And of course I DD it too!!!
thanks
tony
Old Nov 8, 2010 | 09:40 AM
djfury05's Avatar
best is Rev Extreme.. I would also try a new style LS6 valley cover part # 12577927 to keep the oil in the motor.
Old Nov 8, 2010 | 10:24 AM
01ssreda4's Avatar
No need for a catch-can when running the newer style LS-6 valley cover. I believe SDPC carries them for around $70 new. This is what I would do, plus it will clean up your engine bay a lot.
Old Nov 8, 2010 | 10:53 AM
Darkman's Avatar
Hmmm. I have a 2005 CTS-V LS6, presumably with the newer style valley cover. I also have an Elite Engineering Oil Catch Can that accumulates a significant amount of oil/fluid - more than an once per 1K Miles. I do a lot of cold starts in a high humidity environment, which may be a factor.
Old Nov 8, 2010 | 11:27 AM
Jeff Smith's Avatar
Try check on Mike Norris in Indy: he sells Nice oil catch can
I forget his vender name.
Old Nov 8, 2010 | 11:46 AM
Red99TA's Avatar
The LS6 valley cover is not the end-all solution for ingesting oil into the intake. Like the CTS-V guy I also collect oil in my catch can probably 1/2 a tablespoon or so after a hundred miles with some WOT runs thrown in.
Old Nov 8, 2010 | 12:24 PM
v1gray's Avatar
A catch can does indeed work well on an LS based engine. Keeps the intake and heads clean, reduces affect of oil mist on the air/fuel mixture. My experience has been the same as Darkman's.
Old Nov 8, 2010 | 01:56 PM
Turo's Avatar
Saikoumichi dual can here, works wonderfully.
Old Nov 8, 2010 | 02:46 PM
vatechguy3's Avatar
got any pics of this install?
how does it fit?
where did you put it??
rev xtreme is out of business. so can't buy from them.
tony
Old Nov 8, 2010 | 11:59 PM
Turo's Avatar
I don't have any pics of it yet, but the fit and finish are great. It comes with a supplied bracket that I bolted pretty much just like this guy:
https://ls1tech.com/forums/generatio...catch-can.html
But you can really mount it anywhere you have room (later on in that thread someone else posted a pic of their mounted dual can under the car).
Old Nov 9, 2010 | 10:28 AM
v1gray's Avatar
Who's offering the best price on that catch can?
Old Nov 9, 2010 | 10:35 AM
Element's Avatar
How do you drain that setup?
Old Nov 9, 2010 | 11:25 AM
slammin86's Avatar
I have the saikou dual catch can on my LS1gto. Works great and collects oil.
Here are a few older pics of it on my car.
Old Nov 9, 2010 | 12:11 PM
Shockwave179's Avatar
I also have Saikou Dual can. I suppose it may be more difficult to drain (since you basically have to pull it) but other than that it works awesome.
Old Nov 9, 2010 | 01:24 PM
Turo's Avatar
Each can has a sort of "drain plug" at the bottom. Unscrew it and gravity does the rest. Depending on where you install it, you may or may not need to pull it off the engine (still pretty simple and quick to do).
Old Nov 9, 2010 | 02:57 PM
techrunner's Avatar
where are you guys getting these?
Old Nov 9, 2010 | 03:51 PM
Darkman's Avatar
http://www.saikoumichi.com/
Old Nov 9, 2010 | 08:18 PM
sabersaw30's Avatar
Norris catch can is the ticket and probably cheaper.
Old Nov 12, 2010 | 03:17 PM
vatechguy3's Avatar
isn't the norris can too small?
most threads say a 1qt volume is needed.
tony
Old Nov 12, 2010 | 04:29 PM
LilJayV10's Avatar
This.
You can get them from him or several other vendors.
