How to get exotic sound
As counterexamples to those claims here are two builds with cross-plane cranks and equal-length 180-paired headers:
https://www.corvetteforum.com/forums...-the-work.html
https://www.corvetteforum.com/forums...ld-thread.html
this is "in a nutshell", theres a lot more factors. and also the collector at the end of the header is very important. and if this is done correctly, then any exhaust after the collector is indifferent to the engines performance.
the flat plane sounds more exotic because it changes the firing order. so more consecutive engine combustion pulses are together on the same side. so the traditional american v8 one sided header will have more consecutive engine combustion pulses going through it.
