How to get exotic sound
a corsa exhaust is about as exotic as your sound will get...and that isn't saying much. American pushrod V8's have a sound you have to love.
You wouldn't want your Harley to sound like a Honda would you? Why would you want your LS1 to sound like something else?
As for an LS! not"supposed to sound exotic", well you can say an LS1 is not supposed to have twin turbos either. Its the unique sound I am after.
. you expect us to read your mind
If you really want a totally different kind of sound you would really need to go with ultra high revving (7500rpm+),high compression motor.Couple that with a super lightweight reciprocating aseembly and you'll be getting close to the small displacement Italian screamers.
I don't see much you can do exhaust wise (due to the turbo set-up partially) to drastically alter your exhaust note.
The Turbos in the exhaust will not help you get the sound you're looking for. If you were N/A you could couple your cylinders in different ways (think Tri-Y style) but that can cause a power loss.
I personally think turbocharged american V-8's sound pretty damn exotic. There haven't been many made from the factory and you certainly don't see or hear one everyday.
Heres a link to the video post I was talking about.
Check out the pic of this set-up /frame (9D9LS). This will be a twin turbo as well. Notice the holes in the frame for the driveshaft...or more importantly...the 3" dual exhaust!!!
This site shows what a flat plane crank is compared to the crossplane crank an LS1 uses.
http://www.e31.net/engines_e.html
http://www.corsaperf.com/arsctech.htm
http://www.corsaperf.com/audiomenu.htm
You might try and use the mufflers from Corsa's C5 Pace Car Edition or their Titanium Edition. They both sound similiar, but the Touring Edition doesn't quite sound as high pitched. Maybe you can squeeze those mufflers under whatever vehicle you have.
Now if you have about $1,200-$2,400 you can get some BMW mufflers from Tubi, Kellener, Eisenmann, Supersprint or Remus, if they will fit. There are vids here also. Check the first 5 links on the upper left side and look at the dual exhausts for the M5.
http://www.beastpower.com/Merchant2/...Store_Code=BMI
Here is a link to vids using the Tubi exhaust. Great stuff here.
http://www.scuderiasystems.com/M-Media.htm
I know a big part of the sound is determined by the cylinder size, that's why those 5L V12's sound so high pitched. They have much smaller cylinders, while our LS1's get 5.7L out of only 8 cylinders. The larger the cylinder the lower the pitch, roughly speaking. I have to admit the Corsa's do have that exotic sound in the upper rev range. I don't know how they did it, but I love it.
Believe me, there's more to it than the materials they use. Since the last time I posted here I've found a more reasonably priced muffler than can make the LS1's sound more high pitched on the top end. Check out Spintech's GTO video's using their catback system. You can check out the end of this thread for several sound clips.
https://ls1tech.com/forums/showpost....3&postcount=68
A few general note's, headers are always going to give you a higher pitched sound.
Things like cats don't seem to have much effect on the sound.
Resonators like on the GTO's will dull the sound down when combined with the Spintechs (axle back setup), but the catback setup deletes the resonators for that sweet sound high pitched sound.
I know the titanium construction can add to the high pitched sound, but what part of the exhaust does it effect the most? Muffler construction or the tubing? Tubing before the muffler or after the muffler? If I could narrow it down, I would consider making a small portion of the exhaust from titanium, but it's could be a big waste of money.
I'm in the middle of installing an ls1 into an E36...... and after a few beers started to look at the challenge stradale (modena exhaust), and wonder how it would sound behind the ls in the E36?
Has anyone tested an italian catback behind an ls..... any links or sound clips? Or should I just put the beer down, and go to sleep awaiting santa clause
wake up the next day and just do the normal swap cat back... magna flow etc.. etc... ??Cheers guys.
Jeff - San Antonio
https://ls1tech.com/forums/advanced-...e-headers.html
I suspect that the the main thing is just getting the exhaust pulses precisely equally spaced, which of course means precisely equal length headers. Most people who want that sound go a step further and get the primaries from opposite cylinders paired up at the merge collector, and I wonder how much different that makes as compared to just getting the lengths right. It would be interesting to hear both approaches back-to-back.
I surfed today and actually found a top 10 ls swap vid that featured an LS TT in a 599 car with stock ferrari cat back....... sounded like dog Shi$...... perhaps the Worst exhaust tractor like.
I've sobered up and realize it is the ex pulse timing and NOT the catback that make the magic.
So I'll just put a nice cam in the LS and enjoy pissing off transam and bimmer fans.... as the motor is from a transam 2002 formula... and the body is a 99 m3.
will post up a build thread when I get some more momentum. Thx guys. Merry Christmas.
