Ebay 92 and 102mm throttle bodies...
Old 01-30-2011, 08:20 AM
  #41
r572cobra's Avatar
I picked up,the 92 mm tb.the iac hole is not big enough,I think I can make it a little bigger.but other than that.it looks good.
Old 01-30-2011, 08:31 AM
  #42
11SECSS's Avatar
Have you made it to the track to get results .
Old 01-30-2011, 08:44 AM
  #43
r572cobra's Avatar
No,it not on the car yet,hopping for the best,it on a ls3 intake.
Old 01-30-2011, 10:42 PM
  #44
lswon240's Avatar
hey magnet was just wondering if you know will this bolt directly to a fast 90 seen it was already asked just didnt see any answers from anyone any input would be great Thanks
Old 01-30-2011, 11:04 PM
  #45
Magnet's Avatar
The bolt pattern should be identical, but I'm not sure how the opening will coincide.
All I know is the 102 fit the 102mm manifold very well
Old 01-30-2011, 11:19 PM
  #46
Slash8915's Avatar
I like how the 102 version actually has something engraved on it. The 92 version looks plain.
Old 01-30-2011, 11:55 PM
  #47
JoshuaCole67's Avatar
I have the 92mm version.. It does look plain.. Now idk if it was just my TB but I put it on for mock up purposes and already had mine fail.. The black roller that holds the cable on just shot off as did my spring.. After looking at what happened I think the screw backed itself off or was never tightened enough when made.. Just an FYI to go check your screws so your no stranded somewhere... But besides that it fit my fast 90mm.. There was a little gap between the TB and Intake because of the gasket ring but that was just because there is no indention on the back of the TB.. Just a flat surface.. I have pics of it and and when it broke if anyone wants to see them.
Old 01-31-2011, 08:09 AM
  #48
Golf&GM's Avatar
Please post them up, I'd like to see. Did something break or did the screw just back out?
Old 01-31-2011, 08:42 AM
  #49
Magnet's Avatar
Sounds like it just backed out, but pics would be nice. FYI mine is solid..
Old 01-31-2011, 10:09 AM
  #50
r572cobra's Avatar
joshuacole67,other then that problem.did it work okay for you,you said you were driving the car.
Old 01-31-2011, 11:12 AM
  #51
lswon240's Avatar
thanks a lot man I just lost a used fast 90 tb yesterday at the last 20 seconds for $255 id rather go the cheaper route if it still works great again thank you. Also I would like to see pictures of how it fit on the intake please
Old 01-31-2011, 12:43 PM
  #52
Here are the pics of it broken...
And this is what it looked like on.. Looks good in IMO..
The screw just backed out so I reassembled it and tightened the screw with locktite... I haven't got to use it yet.. My motor is still outside of the car...
Old 01-31-2011, 08:00 PM
  #53
Magnet's Avatar
Yea it didn't break which is good news. It just fell apart lol. I might unscrew mine and put it back in with locktight to make sure.
Old 01-31-2011, 08:13 PM
  #54
Swerve7rpm2000's Avatar
Well to bad i took the plunge for the FAST tb already, i woulda bought this piece in a heartbeat! good post
Old 02-01-2011, 12:46 AM
  #55
Ya it didn't break just came out.. Was kinda he'll gettin it back together though
Old 02-01-2011, 01:35 PM
  #56
cody123's Avatar
hey guys would this 102mm be good for my 02 camaro with the ls6 factory intake? What kinda gains do these produce? will it bolt right up no issues?
Old 02-01-2011, 04:17 PM
  #57
Magnet's Avatar
Nope it is the wrong bolt pattern. It is for FAST intake manifolds and some of the newer LS series..
Old 02-02-2011, 11:26 AM
  #58
jcob's Avatar
does anyone know if the 92 will fit the ls3 intake? debating on getting one of these
Old 02-02-2011, 11:29 AM
  #59
Magnet's Avatar
It should as long as it is 4-bolt.
Old 02-10-2011, 07:18 PM
  #60
bayer-z28's Avatar
BUMP
Any tune/driveability issues arise? Anymore springs break or screws back out? I just bought a 102 intake and need a TB now. Bought them separately and is saving me a couple bucks.
Quick Reply: Ebay 92 and 102mm throttle bodies...
