Making my own throttle body?
Ph.D. in HUBRIS
Like the title says. Has anyone ever considered making there own TB? I just got a TBSS intake and have a line on an adapter to use any of the large 3 bolt TB on my 4 bolt intake but the adapter and TB are going to stack up to a decent cost. My thought was i will only be driving this truck in warm weather and mostly at the track.
Any big reason I couldn't use the stock TB cam and TPS and fab my own TB from there. The plan would be to cut out a mounting plate and weld a large(90mm) cylender to it. Drill it for the throtte plate pivot, and mount a tab for a screw to set how far it is open for an idle speed. Thefore worse case if the idle is a bit high or low at any given time I can adjust it.
Is this crazy? TB is such a simple device and on a race only truck i don't see why I need an intake idle air controller?
Thanks.
Thanks.
Ph.D. in HUBRIS
Well the TBSS intake is 90 mm inlet. It is a 408 with 12.5:1 compression. It should be moving some air. A 90 mm TB used is still $150 plus and the adapter is $40 shipped. I could probably build it for $20 or maybe less.
Thanks.
Thanks.
You likely dont have much of an idea of how much engineering and virtual modeling actually goes into designing a throttle body...
Ph.D. in HUBRIS
It isn't a matter of spending the $150. It is a matter that building one seems so simple and anything custom built is much cooler then bought.
I understand lots of enginering goes into a factory TB. But a throttle body is nothing more then a open and close valve and the factory incoperates an intake idle air controller so that the motor will run and idle perfectly in any temp and weather conditions.
Just as a race car doesn't use a choke in a carb I have no need for a IAC on my truck.
If I can build it for $20-$30 and save the rest of the money and again more importantly have a one off TB I would be extreamly happy.
How do these 2 thoughts come out of the same brain in the same post? Listen to yourself. If it was that simple everyone would be doing it. Its a bad idea. Its not simple in any way, shape, or form. However, Im not your pappy so do whatever you like.
I'm sorry, but I refuse to believe that someone who cannot spell simple words in the English language are capable to build a throttle body.
Plus most 90mm throttle bodies are 4 bolt.
Ph.D. in HUBRIS
I am not a perfect speller and typing often exaggerates everyone's miss spellings. That has nothing to do with building a TB.
Just because engineering goes into a factory TB doesn't mean it isn't actually simple. Most of the time is spent designing a product that has a low cost to manufacture, and will still do the job.
I am not quite sure why everyone thinks a TB is some magical device. It is a tube with a flap in side of it. The factory one has a small bypass with an electrically controlled valve and a small coolant passage to keep it from freezing in cold temps. That is it. Just like the city turns your water off if you don't pay the bill, you turn off most of the air when you let off the throttle.
A member offered me a 90 mm TB for really cheap I will probably take it off his hands. I still plan to build one and run it. One to prove how easy it is and two so that it will be another custom part of the truck.
Ph.D. in HUBRIS
Just because it is the first time you have heard of it doesn't mean it can't be done or isn't brilliant. Not saying this is the case with this situation but it has happened and will happened a million times. The idea becomes a reality and revolutionizes the world. I am not planning to move mountains but if I can move a tiny ant hill I would be happy.
If it would only cost you $20 or $30 then what harm would it do to try and make one? If you put it on and it won't idle or run for crap then you know there's more to it than just a block with a flap in it, if not then you just saved some dough. I'd still have it dyno'd against one of the real ones though.
no need for a throttle body at all... push it up to the water box, start the engine then VVRRRROOOOOOOOOMMMMMM shut it down coast up to the staging lanes and as the lights come down just start the engine at the 2nd yellow light and off you go! that way you dont even need to buy a gas pedal and its always WOT and the ultimate !ported !throttle body mod! other money saving tips are plug wires made out of coat hangers sugar free coolaid instead of engine coolant and oak tree twigs in place of hardened pushrods.
sorry... lol just messin with ya.
Basically you are saying something as simple as an electric cut-out is just short of being a functioning throttle body. Im saying you are way out in left field with that theory. Its amazing to me that you think no one has thought of this, attempted it, then failed miserably.
Ph.D. in HUBRIS
Well no one so far has tried and failed in this thread. Yes an electric cutout is all throttle body is. Take a look. Again in a race vehical I don't need an iac. Show me what else is part of the magical TB?
You can do it and it will work...low rpm probably worse than factory made. You are half right. It is not rocket science and most guys on the forums are pack animals. They think certain bolts and parts are something they are not. You can save lots of money and headache if you know what is needed where and the how to of what makes things work. That is where experience and hands on knowledge comes in and you will increase both if you make or fail to make this tb. One of my favorites on this forum is the "you cannot reuse most of the bolts on the ls engines" Goodluck.
