AIR Restriction made out of Galvanized Steel? **Pic***
Went to Home Depot the other night and as I'm wandering around the place like Anderson from Beavis and Butthead (their old neighbor who gets lost in the mega store looking for tile if I recall)
Anyway, I ask a worker to point me to the sheet metal. He takes me to all this galvanized steel used for guttering and stuff. Well I was like.. uh.. okay... I figure 37 cents isn't gonna kill me.
This stuff is friggen flimsy! I was able to cut it with some sissors like thick paper.
Will this work or do I need something thicker? Where does one get actual sheet metal?
It wont melt, if you are going to use them put a nice bead of Hightemp RTV down before you put the plate. If you weld Galvanized steel it makes toxic fumes, I dont know how hot it would have to get to make these fumes, might want to check that out
Your title says you're making restrictor plates, not block off plates. If this is correct that material will work just fine You want to drill a 3/16 hole in the center and forget the RTV crap and just use a stock gasket on either side of the restrictor plate. It won't warp being sandwiched between the flange and the AIR tube.
Oh, sorry, yeah.. I'm making restrictor plates.. I just haven't drilled the holes yet. I've also got 4 brand new AIR gaskets so I can sandwich the restrictor plate.
I'm surprised the tube doesn't come restricted from the header. Do any header companies restrict the tube to begin with?
I used something similar, thin steel used as a perforation for gardening, and I was able to cut it with scissors.
I wouldnt use it as a blockoff plate, but it'll work fine for a restrictor.
Turn it all off, we don't need it anyway. hioSSilvers car came from the factory with the air pump never plugged in.
I know where!!!
My dad owns a steel shop and I have pretty much every metal you can imagine. If you gave me the dimensions of what you wanted and what you wanted it made of I could have it cut. You would have to pay for the shipping to where ever it needs to go.
