Throttle body?
Old Feb 13, 2011 | 11:27 PM
01transampower's Avatar
Question Throttle body?
I have an 01 trans-am. I understand it has the ls6 intake. I would like to purchase a 85mm tb for it. Now i know the port on the ls6 intake is built for the 75mm tb so would putting an 85 on there even with the plate to make the two flow correctly is it bad or should i buy the intake manifold too? Because I hear the ls6 manifold flows pretty good already? Any suggestions?
Old Feb 13, 2011 | 11:29 PM
hitmanws6's Avatar
Port the inlet to match the 85mm TB
Old Feb 14, 2011 | 06:59 AM
BlackIceBlue's Avatar
From: Currently.. Korea. Summer home in paradise.. I mean Wyoming.
If you do this ^ you'll have to use RTV for the gasket because you have to end up cutting the original, but I've seen it done. (I think it was a FAST though).
Old Feb 14, 2011 | 07:34 AM
MonmouthCtyLS7's Avatar
Screw the 85mm just port the stocker
Old Feb 15, 2011 | 04:20 AM
How much of a gain could i see out of porting and polishing the stocker? or how about an 80mm with a port and polish job?
Old Feb 15, 2011 | 08:24 AM
W/ the ported stock I noticed improved throttle responce...some shops have dyno'd around 7 hp give or take...you wont see anymore power w/ a ported 80mm on stock cubes/motor.
Old Feb 15, 2011 | 08:36 AM
bayer-z28's Avatar
FWIW: I made 414/372 with h/c on an LS6 intake and ported stock TB. I noticed a solid gain over the stocker when I was all bolt-ons (at the time.) It made the car a little more touchy.
Old Feb 15, 2011 | 09:12 AM
Rare96LT1Formula's Avatar
Agreed
Old Feb 15, 2011 | 02:14 PM
How much should i expect to pay to get it port and polished? I know i could do it myself but i dont trust myself with something that dictates whether the car runs correctly or not.
