Hooker longtubes on LS6 Crate Engine HELP!!!
Old Mar 6, 2011 | 11:41 AM
  #41
Greekey's Avatar
F*** that crap. I would of threw them things threw summits front door haha. I honestly would of taken them back.
Old Mar 6, 2011 | 12:06 PM
  #42
Black98T/A's Avatar
I'm grinding it and letting my grinder cool....this is ridiculous!
Old Mar 6, 2011 | 03:38 PM
  #43
agenthol302's Avatar
i really hope this works out for ya cuz this sucks...i was going to order some hooker headers of summit for my 98 z28 too
Old Mar 6, 2011 | 04:13 PM
  #44
Black98T/A's Avatar
Nope I've given up...I grounded a huge chunk off the k member...put the back bolt in...the front bolts don't line up because it still hits and it looks like I'd have to take a lot more out the k member...which I'm not. I'm going to have to buy another set from them...and send these back and start from there.
Old Mar 6, 2011 | 04:42 PM
  #45
Black98T/A's Avatar
So if I get different headers do you think that will solve my problem? I don't get why it's hitting...the motor mounts are new..could the header holes be off?
Old Mar 6, 2011 | 04:50 PM
  #46
redbird555's Avatar
some headers just dont fit as well as others usually do to design or just a bad jig when they were welded together. If you get another set take my and everyone elses advice and get a set of bbk's if you dont wanna spend a lot of money. They look great and i havent seen anyone complain about fitment. When I put mine in they literally slipped right in and arent close to hitting any part of the k member
Old Mar 6, 2011 | 04:56 PM
  #47
Black98T/A's Avatar
I already have a TSP y pipe don't the BBk's only come with the Y-pipe? Then I have to send my y pipe back. :sad:
Old Mar 6, 2011 | 05:17 PM
  #48
redbird555's Avatar
you could do that or you could just have an exhaust shop modify the tsp y pipe to fit. the bbks are 365 in chrome and that comes with the y so it wouldnt be that much more if any more money than the hookers.
Old Mar 7, 2011 | 07:11 AM
  #49
badmfkr's Avatar
Originally Posted by Black98T/A
This is my problem...on the passenger side the tube is hitting the top of the k member when the bolts are lined up as best as I can get them
I feel for you bro.
1.grinding a K memeber a little isn't that big a deal however I wounld'nt grind though a weld weakening the K member.
2. concider the alternative of heating up the LT and pry it off the spots where they contact. basically dinging the LT.
my advice send them back Summit is known for excellent customer service.
don't start hating you'r car because of crumie parts, contacting LTs will lead to false knock issuses.
Old Mar 7, 2011 | 10:03 AM
  #50
Black98T/A's Avatar
Originally Posted by badmfkr
I feel for you bro.
There's a big gash and they still hit...I grind a spot away and then it hits in another. I ordered another set PN 2470-HKR which are the ones I should have got anyway when I told the guy from summit I wanted the ones without air and egr..go figure they are for 98-02 f bodies. No one still hasn't been able to explain the difference between the 2468 and 2469. Hopefully I got some headers that were off if not.
Old Mar 7, 2011 | 12:49 PM
  #51
Snake_Skinner's Avatar
I feel for you bro.
^ Agreed 100%. Not so much on the alternative #2 since you've already grinded the K so much and im not a fan of dinging up some BNIB LT's.
If you already got a TSP Y, spend a lil extra and get some 1 7/8th's IMO.
Old Mar 11, 2011 | 10:25 AM
  #52
Black98T/A's Avatar
Originally Posted by sjsingle1
dont blame the car..........blame the hookers.......did you put in new motor mounts?
Well I got my second set of hookers and they also don't fit!
I have new poly mounts...and long tube headers hit the k member enough where I can't even install them on the passenger side. If I put the the back bolt in the front header holes don't line up and sit too low...and that's with grinding quite a bit off the k member.
What could the problem be?
It looks like I have the only Trans Am you can't put long tube headers on without major modifications so so I can either grind down the k till its almost off or send both sets of headers and the Y pipe back and put the exhaust manifolds back on..leave them or put a set of mid lengths on?
Old Mar 11, 2011 | 10:26 AM
  #53
Black98T/A's Avatar
Oh yeah the headers I got don't even have the o2 holes punched out.
Old Mar 11, 2011 | 11:17 AM
  #54
PheonixLS1's Avatar
Are ceramic pacesetters an option for you.?!?!?!
Old Mar 11, 2011 | 11:31 AM
  #55
Black98T/A's Avatar
why would pacesetters be any different?
Old Mar 11, 2011 | 12:27 PM
  #56
Black98T/A's Avatar
I 3/4 don't fit...why would I expect 1 7/8 to?
Old Mar 11, 2011 | 12:29 PM
  #57
sandsk8erz400's Avatar
Is it possible your car was ever in a wreck and things may be tweaked just enough to be causing the problems?
Old Mar 11, 2011 | 01:00 PM
  #58
Black98T/A's Avatar
yes the car was in a front end wreck before I bought it..the front stabilizer bar looks new but the car drives staright...I thought about this but don't know if it could have any thing to do with it?
Old Mar 11, 2011 | 01:19 PM
  #59
sjsingle1's Avatar
if the K fits....dont think that any frame damage could keep the headers from fitting.......i blame hooker..........the motor mounts were not put in backwards? motor mount pedestals not switched? ........blame hooker
Old Mar 11, 2011 | 03:56 PM
  #60
speedracer2536's Avatar
What brand are your poly mounts.. There is a brand that sags really bad.. I cant remember which.. If they fit fine 10k miles ago and now they dont.. Thats the only part that would wear and cause this issue.. My vote is new motor mounts.. Go with energy suspension or solid motor mounts from bmr or motivative.. Both sponsors here..
