***help*** identify this wire
Old Mar 4, 2011 | 07:48 AM
Punisher_ws7's Avatar
Default ***help*** identify this wire
Well got the car back from getting the motor installed, and now im in the process of getting everything else hooked up.. i have this wire laying here that i didn't take off so i have no idea where it goes... Through searching pictures i have narrowed it down but still havent pin pointed where it goes..
Thanks
Old Mar 4, 2011 | 08:15 AM
was starting to think it came from alternator and went to fuse box but idk
Old Mar 4, 2011 | 08:19 AM
bayer-z28's Avatar
That's what I was thinking too. But I'm not sure either.
Old Mar 4, 2011 | 08:49 AM
RARON455's Avatar
Take a pic of the pigtails on the ends, There is another clip like that that goes into the OIL level sensor on the pan. but cant realy see the clip in that pic.
Old Mar 4, 2011 | 11:30 AM
91sbcamaro's Avatar
It looks like the wire that connects to the block down by the starter, I believe it is routed along with the starter wires. Their is a bolt hold in the side of the block that it bolts to.
Old Mar 4, 2011 | 02:43 PM
ima look there and see.. pretty sure its already hooked up tho..
Old Mar 4, 2011 | 03:01 PM
just went out and checked.. the wire you speak of is connected.
Old Mar 4, 2011 | 03:36 PM
sjsingle1's Avatar
that dont look like a GM part
Old Mar 4, 2011 | 08:17 PM
S10xGN's Avatar
Looks like it could be the engine block ground wire...
Old Mar 7, 2011 | 12:34 PM
and do you know where it goes on the block?
Old Mar 7, 2011 | 02:18 PM
NVR_SPDS's Avatar
I just swapped my engine, and pulled my wife's and that cable doesn't look familiar. The cable that goes to the alternator is red. Is the starter hooked up? The only place I could think of that cable would be used is the starter or block ground, but even then, I believe both those terminate into the battery cable. The engine block ground on the drivers side is a flat copper strap, well atleast on our 00 and 01 it is.
Old Mar 7, 2011 | 07:56 PM
S10xGN's Avatar
No, but maybe someone with your year model will answer back...
Old Mar 8, 2011 | 08:57 PM
thanks for the replies... still havent located where this goes
