Removed ram air ducts... Heavy rain :/
1 Post
After you've driven a little ways pop the hood and check the filter to see if its wet or even close to being wet, do this periodicaly and see. If it is yes if not then your good to go!
Pontiacerator
I get a direct shot of air to the filter on my homemade cold air setup on the standard hood - very much like a WS6 hood without baffles. I've tested it in heavy rain, and although my filter has never gotten wet, water has accummulated on the sheet metal below it.
My solution will work on you car like this: Get some sheet plastic and cut it in the shape of the grilles. Attach velcro to those pieces and the corners of the grilles. Reinstall your grilles, and then just attach your "rain blockers" whenever it rains heavily and no worries.
Or if you want to leave the grilles off, you could put the velcro on the grille mounting tabs in the scoops.
1 Post
Definatly, ive got 94k on mine. What i would advise though is if you dont know the condition of your engine to go through it and find out before. Nitrous is completely safe when done right and shouldn't be a problem, just read up on it alot first and ask questions ect. When i got my kit (sitting in my room )off someone here the solenoids were not as described and when i asked the guy if i could send it back at my charge he declined so paypal is now reviewing it and either it will go through and ill get another or i will keep the kit and just toss the old solenoids and buy new ones. Either way im going to be happy cause i want to get it on but i dont want to end up spending alot more but thats life i guess. However right around the same time i noticed my mpg fell from 30 to 10 mpg so ive been going through the engine checking for vacuum leaks, compression tests, oil stuff, checking sensor readings and everything. Its a pita but a blessing in disguise cause i dont know what would have happened if i threw it on before. Im not the original owner so i needed to do this anyways. Newb mistake in my opinion and i would have been a dumbass not doing this before but at least it happened before anything went down. So i would advise a good thorough engine check and all to make sure everything is in top condition then go for it!
Dude i live in colorado and drive mine with out tabs. Its my DD. It see's snow rain all the great weather here in colorado and have no problems. It all depends on your filter. If you have a crap paper filter replace it with a K&N. If you have a K&N dont worry check it but you should be fine. Its worth the mod less restrictive air to your motor.
1 Post
Vacuum leak is really simple, you prob know but just in case you dont, just take carb cleaner and before the engine gets too hot spray it around the hoses and potential leak areas and listen to a change in the idle of the car, it should make a pretty noticable change that you will be able to tell and locate. Really basic, im sure you know but i didnt once and if you dont then you can go out and do it right away and see! I've heard you may need to disconnect the IAC value for the best results..
Had a Harwood WS6 hood on my T/A and made it functional. No grilles with my K&N fipk kit sitting right behind the inlets. I live in south Florida an the car was my DD. I drove through hurricanes in that car, literally, and never even had water on my MAF or in my intake let alone enough to hydrolock a motor. U guys have to remember its not that easy to get enough water in there to hydrolock it
