ls6 intake swap
Found an ls6 intake for my 99 z28 vert. I know I can reuse the water lines if I remove the checkerboard on the bottom of the intake. Can I also reuse my fuel rails and injectors? Throttle body? Planning on replacing the orings on the head side, do I need to replace the tb oring too? What about the screws that hold the intake down, reuse them too? Anything else I need to know? Thanks for your patience.
All jokes aside though, it should be a pretty simple swap. There's a how-to on LS1howto that includes parts necessary as well as GM P/N's.
Heres a pic of the oil sending unit behind the intake. Its hard to see but look closely on the left side of the connector on the back of the intake. Its a black cylinder looking thing
