gains from a 4 inch bore
Old Apr 1, 2011 | 06:01 AM
Floorman279's Avatar
Default gains from a 4 inch bore
Wat kind of gains would i see if i bored my 1998 ls1 from the 3.896 bore to a 4.000 inch? Its possible even tho the walls r thin rite
Old Apr 1, 2011 | 06:14 AM
96 Comp T/A's Avatar
Not possible, without sleeving. 3.905 is as big as you can go.
Old Apr 1, 2011 | 06:42 AM
Ok i figured i was reallystretchin it.
Old Apr 4, 2011 | 01:21 PM
ivan_key's Avatar
get an ls2 block
Old Apr 4, 2011 | 06:48 PM
bww3588's Avatar
on 97-98 blocks, 3.903 is max.
99+ 3.908 is max but pushing your luck. 3.905 is usually said to be max.
Old Apr 4, 2011 | 10:45 PM
180ls1's Avatar
im with the posters above
Old Apr 5, 2011 | 01:08 AM
gta3uzi's Avatar
At 4.0 I think you would be running on virgin aluminum cylinder walls.
Old Apr 5, 2011 | 06:54 AM
BOBS99SS's Avatar
Captain Double Post
Ls2 block is my vote,
Old Apr 5, 2011 | 08:01 AM
Randy WS6's Avatar
Like said above, Get a LS2 block they are 4.00" bore from the factory, I have a LS2 in my car right now and its bored .030" over (4.030") But a LS1 can not be bored that big, the sleeve are just to thin, .005" is about max. And you can not bore any LS block .104" over like your wanting to do with factory sleeves.
