NGK Iridium IX Spark Plugs?
Getting ready to install my LT's and ORY, so I thought it might be a good idea to go ahead and change my plugs and wires. I've heard good things about NGK's Iridium plugs, but are they really any better than platinum or copper? Also need some advice on wires and which ones to choose...MSD, Taylor, any suggestions?
Iridium is better than platinum and copper. However do you really need something better than copper? Most people will tell you no. I have the regular NGK-55's and they work fine for me. I might need to change them sooner than I would Iridium though.
I have Denso Iridiums. Don't know why I put them in originally, only it was a NEWBIE mistake. If I knew then, what I know now i would have installed NGK TR-55's
Just install the '55's, save the other money for other mods.
Tony
Tony
I have the TR55 IX, I installed them with a set of MSD wires. The cars feels like new again, and it evened out my idle some. I'm sure the TR55's are just as good, I just didnt wanna change em that often
Originally Posted by Svingos129
Well...I don't plan on spraying or running boost anytime soon, so I'll just go with the NGK TR55's
Anybody got suggestions on plug wires???
Thanks in advance,
Justin
I got the NGK Iri's, I didnt have any KR on the dyno runs with my new cam, car runs great and from what I have learned is that they last Longer then Plates and spark hotter then copper. Alot of turbo guys i know run them and mostly all sport bikes run them so they must be doing something right.
I have MSD wires and am VERY VERY happy with them. Other people have had problems with wires pulling apart but after 45K miles and MANY MANY times of putting them on and taking them off, they are still good as new (basically). I'm relocating the coil packs off the heads so won't be using THESE wires anymore, but I'm still going to be using MSD wires (making a custom length set).
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by C_B64
how much are the irridiums?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Tony
The advantage of the iridium plugs is that they will last longer than copper, and longer than platinum. So you hardly ever have to change them. That's why I bought them.
There is no performance advantage, it's just a maintenance issue. If you've got enough to do without changing spark plugs every 30K miles, buy the iridiums.
