Crank Pulley Wont Come Off
Were these cheap pullers from HF? I used the 'chrysler style' puller, autozone rents them for free:
http://www.autozone.com/autozone/acc...er=391370_0_0_
Yes I agree this is the best one out there for a stock pulley. I liked it so much I went and bought one. I found that it and a good impact will bust em loose.
Make sure the center stem on your puller is pushing against the end of the crank and not the pulley. These are not really on there all that tight, mine came off with a small hand wrench once the bolt was out...
Seems like some of the LS pullies do NOT like to be messed with. Mine was the same way almost every damn time I *** with it. Unless I'm doing a cam swap. THIS time I did a UDP about a month ago, I had to beat the **** out of the pulley, crank on the puller a turn or three, then beat the **** out of it again to knock it lose a little, crank on the puller some more.. etc etc. I ended up breaking the edge of the pulley, but it was getting replaced anyway.
