EGR question
Old Apr 18, 2011 | 10:06 AM
LS1121's Avatar
Talking EGR question
I'm replacing my exhaust manifolds on my 98 Z28 with manifolds from a 2000 and the tube that goes from the EGR valve to the passenger side exhaust manifold is different, can I just cut the tube and insert some type of rubber hose or will this be a Problem? Thanx for any Help.
Old Apr 18, 2011 | 01:14 PM
99 Blue Bird's Avatar
y did u switch the manifolds to 2000 instead of 01-02 years? 98 to 00 are all pretty much the same. the 01 02 manifolds are the good ones.
Old Apr 18, 2011 | 11:56 PM
Cold06's Avatar
get headers you'll thank me later! pacesetter has them for 400
Old Apr 19, 2011 | 12:25 AM
LS1121's Avatar
I'm replacing my cats with the newer style and the 98-99 manifolds won't adapt to the newer cats. I still need the EGR that is not on the 01-02.
Old Apr 19, 2011 | 02:19 AM
blown97gts's Avatar
great advice!
Old Apr 19, 2011 | 07:36 AM
LS1121's Avatar
But..............can anyone answer my Question????????
Old Apr 19, 2011 | 07:40 AM
jsteele90's Avatar
as long as it is some type of high temp hose i dont think it will be a problem
Old Apr 19, 2011 | 01:14 PM
ok i was just curious. was not sure if you were doing it for a performance upgrade. thats y i mentioned the 01-02 years. before cutting it off try to heat the tube and twist it a tad to be able to bolt it to the manifold.
Old Apr 19, 2011 | 07:51 PM
LS1121's Avatar
OK Great thans for the suggestions.
