Replacement Air Flow Straighteners
Old Jul 2, 2011 | 11:58 AM
  #81
ta-stanger's Avatar
Has anyone other then me had a problem getting any email back from this company? It's like they don't exist unless it is an order you are placing! WTF
Old Jul 6, 2011 | 08:56 PM
  #82
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Did you not get a business card with your order? The phone number is on the card.
Anyways, I finally got the chance to get mine installed this weekend. I can definately tell a difference, and I don't believe it's placebo. I didn't have to glue mine at all, as it fit tight as hell.
I've noticed a slightly smoother idle, as well as a smoother acceleration, if that makes sense. Also in cruise control, 6th gear, 3.42's, when going over hills or long bridges with a decent incline, it seems like it's just smoother and easier for the car itself.
I popped out my old screen and held it up to the new one, and seriously, holy ****. What a difference. The stocker is such a resriction it isn't even funny. Also, the combs themselves are much deeper. Seems to me airflow would stay straighter longer.
I have no tuning software nor experience in the matter, but it's definately something I can tell seat of the pants. Even my wife noticed. She took the car to get a few groceries and when she came home she said, "Well, I guess the P&P throttle body was worth it. Car seemed to idle and accelerate a little better."
I told her that wasn't the throttle body b/c I hadn't yet installed it. It was still sitting in the box.
All in all, for 10 bucks, I think it's an awesome mod that I would reccomend to anyone.
Old Jul 7, 2011 | 10:23 AM
  #83
01 ss vert's Avatar
Thanks for the feedback. I'm in!
Old Jul 7, 2011 | 08:36 PM
  #84
dr_whigham's Avatar
The Scammer Hammer
Yeah, that took a while, I know. Kinda shitty considering it took all of 10 minutes. I've been working so much lately I don't even have "Miller Time" anymore!
Old Jul 9, 2011 | 12:39 PM
  #85
Rare96LT1Formula's Avatar
Ordered one for mine. 5.1 ratio 86mm. It'll be nice to have a screen in my maf again lol
Old Jul 9, 2011 | 03:00 PM
  #86
99Bluz28's Avatar
Just got mine in the mail yesterday, should be a nice step-up in flow over the stock screen.
Old Jul 9, 2011 | 03:29 PM
  #87
Element's Avatar
Ordered mine about a week ago, and haven't seen it in the mail yet. Hopefully it comes in some time soon.
Old Jul 9, 2011 | 07:53 PM
  #88
dr_whigham's Avatar
The Scammer Hammer
Once you get the old one out, and actaully hold it up to the new one, it's a "holy ****" moment.
All you can do is look at your poor LS1, shake your head and feel like a monster for trying to make that poor engine breathe through that abomination.
Old Jul 17, 2011 | 12:52 AM
  #89
dr_whigham's Avatar
The Scammer Hammer
Well, update time. Anyone else get it put on yet?
Old Jul 17, 2011 | 08:09 AM
  #90
Element's Avatar
Got mine installed, but the car's still in the air waiting on suspension parts. Definitely a lot better looking (for flow) than the stock piece, though.
Old Jul 17, 2011 | 12:01 PM
  #91
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I ordered up a pair of these for our LSx vehicles.
Just to be clear when ordering from SaxonPC:
2002 LS1 F-body = 86mm
2007 LS2 TBSS = 96mm
This modification is the perfect compromise between other MAF-hacking options as you will gain flow and improve/maintain functionality; at $10 each it is a no brainer.
Old Jul 18, 2011 | 08:32 AM
  #92
Put mine in over the weekend. I'm thinking the previous owner of my car ported the inside of the MAF housing cause the fitment of the screen wasn't very good. I haven't really noticed much of a difference but for $10 feel like it was worth the money especially since my MAF was de-screened by the previous owner.
Old Jul 18, 2011 | 10:48 AM
  #93
01 ss vert's Avatar
I think you will notice more lower end, low speed torque, based on the physics. WOT I doubt will be noticable. $10 is not much.
Old Jul 19, 2011 | 12:44 PM
  #94
Cosmos's Avatar
How would this work with an SD tune? Wondering if I should run one when I tune for SD.
Old Jul 19, 2011 | 12:57 PM
  #95
SSpdDmon's Avatar
Probably not necessary. The point of this is to promote consistent airflow readings across the MAF sensor wires instead of the turbulent airflow that can be seen with de-screened MAF housings. Since the SD calculation works off of MAP, RPM, etc., you shouldn't have to worry.
Old Jul 19, 2011 | 01:03 PM
  #96
Cosmos's Avatar
Thanks for the input
Old Jul 21, 2011 | 05:29 AM
  #97
Ballerado's Avatar
Anybody ordered one for a tsp 100mm maf? Id like to get a screen for mine before I go get it tuned to just try and simplify everything from the get go if possible. Also, what ratio would be most optimal for the 100mm maf? 5:1? sort of confused when looking at the options in the drop down menu on that site.
Old Jul 22, 2011 | 10:52 PM
  #98
dr_whigham's Avatar
The Scammer Hammer
Well, I have a new problem / update. I think my MAF itself may have both legs in the grave.
For the life of me, I can't get my idle to, well, idle. It's constantly searching, so to speak. It's kinda scary though when it wants to hang around 3k. It normally wants 1600 though.
It'll come down to nowmal (850ish) for a second, then just starts going ballistic, like it can't find it. I initially though vacuum leak, but haven't found one yet. I then figured, ok, it must be a bad tps / iac, so I bouth both brand new, both AC Delco, reset the PCM, and that's when it got worse.
Before the new IAC and TPS, the highest it would go was the afformentioned 1600. After, it would shoot to 3000. I then decided to check the MAF itself.... I was already 100 miles into a 160 mile drive, and just started to get into civilization again off the interstate, so I pulled over, turned off the car, unplugged the MAF, started and drove.
Guess what? MUCH better idle, and no searching.
Does this mean my MAF is shot?
Does it mean it could still be a vacuum leak and now the motor just isn't seeing it due to the disconnected MAF?
The car IS idleing better now. Not perfect, at all, but it doesn't climb and search. It stays around 950 - 1100.
Old Jul 23, 2011 | 06:09 AM
  #99
ta-stanger's Avatar
Did you try just taking the straightener out? MIne did the same thing. It was all over the place up and down. Went to normal when I took it out.
Old Jul 24, 2011 | 11:22 AM
  #100
dr_whigham's Avatar
The Scammer Hammer
When I unplugged the MAF the surging went away. I wonder if I didn't screw it up when I descreened it.
I have another MAF on the way that only has 37k on it and still has the screen. I'mm throw it on and see if it gets better. Then I'll take the MAF end off and throw mine on that has the screen to confirm if it's a bad maf or the screen itself.
The way the problem immidiately rectified itself though when I unplugged it makes me think it's just the MAF.
It'll be about a week and a half before I have an update.
