Replacement Air Flow Straighteners
Old Nov 30, 2012 | 08:52 AM
  #121
thunderstruck507's Avatar
I did put one of these screens in my 85mm GM MAF. Prior the idle had an ever so slight stumble on occasion and since adding this it is either gone or reduced below my detection. For the price, I think it is a great investment since it allows more flow than stock but is better than running with no screen (especially for those of us with 90* bends in the intake tract.
Old Nov 30, 2012 | 10:02 AM
  #122
saxxon68's Avatar
Originally Posted by 01ssreda4
Stock TB is 75mm on an LS1. 78 is an internet myth. Some later GM's got the 85mm MAF which was coupled with a later style 4 bolt TB that was 90mm. But that was after fbodys/LS1s were dead and gone.
An internet myth, good one
Old Dec 29, 2012 | 12:34 AM
  #123
RJDio's Avatar
I had no problems with descreened stock, or descreened SLP MAF, but I didn't want any issues during next tune so I installed the aluminum photomesh. I appreciate the info. I could have done a better job making it neater on edges but if I ever do it again I will take more time.
Attached Thumbnails Replacement Air Flow Straighteners-screen1.jpg   Replacement Air Flow Straighteners-screen3.jpg   Replacement Air Flow Straighteners-screen4.jpg
Old Mar 29, 2013 | 03:10 PM
  #124
blown97ss's Avatar
just installed the air straightener for my 99 camaro. so far ive noticed a better idle before it was at 900 rpm now its around 750. just need drive it a couple miles to see if it help get some better mpg.
Old May 12, 2013 | 07:08 PM
  #125
38DD2436's Avatar
I just ordered. Worth a shot
Old May 12, 2013 | 08:10 PM
  #126
BAD2theBONE's Avatar
Very interesting after reading this whole thread, less restrictive and very affordable! Hell, for $12 I'll give it a shot! Order placed!
Old May 13, 2013 | 04:15 PM
  #127
Blk98Vert's Avatar
I have one on my GTO, works great!
Old Apr 16, 2014 | 11:16 AM
  #128
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
So guys, just for confirmation...
GM 85mm MAF I need the same ratio and all as an LS1 MAF, but select the 96mm diameter, correct? I just want to ensure it doesn't PROTRUDE OUT from the lip of the MAF itself.
3/16, 5:1, and 96mm correct?
Old Apr 28, 2014 | 11:59 AM
  #129
jig's Avatar
jig
for a stock MAF what is that depth, ratio, and size i should get??
Old Apr 28, 2014 | 08:31 PM
  #130
jg rider's Avatar
Wow ! I started this in 2011 and it's still going. With my sock maf I used the 5/8" thickness. I laid the screen on a flat surface, put the maf on top and pushed down.
At first it will look like the screen protrudes out, but if you look into the maf opening you'll see a step down. Just push on the maf until the screen seats into the step down.
I suggest you reread posts 1, 30 & 41
Old Apr 29, 2014 | 07:47 AM
  #131
LS1-450's Avatar
Originally Posted by jimmyblue
Some cars seem to notice descreening, some not. I've been using a
descreened 85mm truck MAF for years without issue, with various
GM MAF tables. Personally I'd rather tweak it right in the tables than
put another restriction back in the lineup.
, those of us w/ tuning software have access to correct for it without the use of such things. Further, GM does not even use 'em in many of the later models.
Am not claiming that what has been offered in this thread isn't beneficial to those without access to modifying their MAF table. Am simply agreeing w/ jblue that in the models discussed here, that also use screens, tuning the MAF table & then leaving the area around the MAF alone is more effective. Simply rotating the MAF can alter the airflow & render the MAF table in-correct.
