How does the new LS carb manifold work?
Old Feb 22, 2004 | 09:04 PM
30th TA 0219's Avatar
Default How does the new LS carb manifold work?
And more importantly, WHY?!?!?
Old Feb 23, 2004 | 08:11 AM
jimmyblue's Avatar
Moderator
Because then you can tune the vehicle with
a screwdriver and a timeslip, the way God
and nature intended?
Old Feb 23, 2004 | 09:44 AM
2xLS1's Avatar
It's made more for putting a LS1 into another vehicle. I'd use it if I was building a street rod.
Old Feb 23, 2004 | 10:46 AM
well, duh! My point is who would want the LS motor without the EFI?
On the other hand, I guess we will get a chance to see how much of a bottleneck teh "plastic" manifolds really are once somebody puts a big *** carb and mostr 300 shot on, huh?
Old Feb 23, 2004 | 01:24 PM
dazman's Avatar
uh.... i DO believe that the jets control how much fuel is put in the car and those screws that you see to "tune" the car is for idle only...
or atleast that is what i was taught...
mike
Old Feb 23, 2004 | 02:26 PM
Turnin'LT4's Avatar
Also...you can make more power from a carb.
Old Feb 23, 2004 | 02:44 PM
Tally TransAm's Avatar
mike
you do know you can basically take apart a carb and change those jets
WITH A SCREWDRIVER
and there are many adjustments on the outside of a carb, idle, mixture, you can adjust the accellerator pumps, secondaries, etc . . .
Old Feb 23, 2004 | 03:51 PM
GainesvilleLS1's Avatar
Personally, I see the benefit is more directed at serious index racing. An EFI system is always trying to find stoich, so its not so easy to predict what you'll run. Which aint good. Cause you'll break out and lose.
A carb & combined with a locked down ignition curve is consistent. A simple weather station in your trailer at the track, and viola, you got easy throttle stop settings to compensate for weather conditions. Consistent ET's... which is how you win races (assuming you got a consistent launch).
Plus I think there is some real benefit to the flexibility, availability & affordability of going to a carb. Perfect for the home tuner. No messing with error codes, programming, dyno tuning, etc.
BUT, for an everday street driver? Or even a fun street strip car? I'll take the EFI.
Old Feb 23, 2004 | 07:00 PM
noah98SS's Avatar
who makes the intake and where can i see it my brother was thinkin of anLS1 for his 64 nova,he said sumthin about that intake
Old Feb 23, 2004 | 08:28 PM
Slow Z28's Avatar
Edelbrock makes a a dual plane
GM Performance Parts make a single plane
do a search for carb intakes on this sites search feature and you'll find pics and links with more pics
Chris
Old Feb 23, 2004 | 09:38 PM
99 Black Bird T/A's Avatar
The intake was created for a racing series.
It can be used with carb or with EFI. If tuning I've been told a MAF less speed density tune is possible and can be done with LS1edit by an experienced tuner. Likewise, it should be possible with an elbow and tubing to adapt and use a MAF. The intake would need a placed drilled to add the MAF sensor in either case.
The intake has bungs for port fuel injection or NOS etc. There is room to do some porting and port matching.
I think one big advantage could with the single plane design the torque peak could be higher than with an LS6. If the torque peak is moved up the rpm band, it should be possible to have the HP peak higher. The higher torque band might also enable squeezing a few more ponies out.
I have helped several people get the GMPP over the last few months. If interested in more info let me know, I can help you get one now if you want it.
Old Feb 23, 2004 | 10:02 PM
Ryan K's Avatar
Pathological Modifier
This is why:
Ryan K.
Old Feb 23, 2004 | 10:14 PM
Slow Z28's Avatar
YUMMY!!!!!
Ryan, how you running the coils? is that something that the aftermarket engine management includes?
Old Feb 23, 2004 | 11:03 PM
i just nutted in my pants
Old Feb 23, 2004 | 11:12 PM
Ryan K's Avatar
I have my coils relocated. But I am going to have to move them, I think this time, I am going to put them on the strut towers.
Ryan K.
Old Feb 24, 2004 | 10:36 AM
1fastWS6's Avatar
LMAO!! I did too. That intake setup is sweet! Post pics when you get it on the motor too!
Old Feb 24, 2004 | 11:25 AM
Ryan K's Avatar
Will Do, I am going to trial fit it today.
Ryan K.
Old Feb 24, 2004 | 12:42 PM
C4VetteLS1's Avatar
Are you going to run a MAF with this setup or goto a speed density tune?
Old Feb 24, 2004 | 02:40 PM
Keith's Avatar
oooogle ooogle oooogle
Yummy indeed
Old Feb 27, 2004 | 12:46 PM
Solid346's Avatar
Ryen,
what kind of 4 barrel you are using?
