Need Help with Fuse ( + - ) wires
the + hot is obvious, but not sure where the ground with the rubber boot goes.
I attached a picture of what I am looking for, thanks in advance.
Take thge rubber boot off the ground and use it on the pos terminal that you have connected on the box. You want to sheild that from anything loose hitting it.
Then connected the battery ground to the body or engine-block or something where a common ground can be found.
http://parts.nalleygmc.com/images/pa...08MF02-031.JPG
This diagram isn't 1:1 but at the top you can see the little rubber boot. problem with this diagram it looks like BOTH goto the pos fuse box - can just imagine how bad that would have toasted my electrical system.
I redid that diagram
It would appear someone at GM deamed it intelligent to make a wire coming off the hot NOT RED, like the rest of the car. (other picture) Heck, sure both are HOT but come one - red stripped? labeled? ANYTHING but black.
WHY OH WHY???
Thanks folks, knew y'all would have an answer.
Chilton SUCKED at helping here, no pictures of this and all black and white. hard to see color in b/w.
I still think it was stupid of GM to make a hot wire black.
black is always the ground (or so I thought)'
