Ls6 intake install
Old Jul 25, 2011 | 09:54 AM
BashamWS6's Avatar
Banned Scammer
Default Ls6 intake install
http://www.ls1howto.com/index.php?article=5
Holy crap...is it this Complicated or is it just very detailed and i am over reacting?
Also do i need lube/grease for the intake gaskets and injector orings?
I bought the coolant cross over from ws6 store so that should be good....
But yeah...someone said something about a new knock sensor?
Old Jul 25, 2011 | 10:02 AM
omarrakeen's Avatar
I read that article before. it surly looks hard to do, but everyone said its a piece of cake to get done. am going thru this in 2 weeks time. let me know how it goes and yea i believe its the oil psi sensor? anyway good luck.
Old Jul 25, 2011 | 10:04 AM
mike171562's Avatar
It's not that difficult, just go slow and take your time. Make sure you reach back behind the intake and disconnect the sensor and the small vacuum line before you yank it out.
When your pulling it out, reach your hand behind it and guide the rubber hose that goes to your brake booster over your Oil Pressure Sending unit or it will break.
You shouldnt have to lube your injector O-rings unless your taking out your injectors
Old Jul 25, 2011 | 10:18 AM
BashamWS6's Avatar
Banned Scammer
Well ill b taking the rails off my ls1 and putting them on the ls1
Old Jul 25, 2011 | 10:30 AM
skopers3's Avatar
Not bad at all. Search for a LS6 instll video on here/youtube. that's what I used and it was really helpful
Old Jul 25, 2011 | 10:36 AM
TheBlueKnight's Avatar
I made the install video. Unfortunetely the first half was lost but I still have the second half which is my removing the fins on the bottom of the intake and re installing it. It's very simple if you follow the steps on the howto you listed above. Just take your time, have a couple cold sodas/beers and play some good music. You'll be done in no time.
https://ls1tech.com/forums/generatio...old-video.html
Old Jul 25, 2011 | 11:06 AM
johnLs1camaro's Avatar
its a very easy swap, it just take me 45min to swap out intakes now.. just take your time and you will find out its really easy.
Old Jul 25, 2011 | 11:45 AM
sjsingle1's Avatar
new intake gaskets......dont be cheap.....get new.......new knock sensors and wiring harness......new OPSU...thats about it
Old Jul 25, 2011 | 12:06 PM
z99ls1's Avatar
Restricted User
It's not hard you just have to be carfull not to break the opsu
Old Jul 25, 2011 | 12:18 PM
R6cowboy's Avatar
It really is quite simple. You will realize it when you get into it. I use a very small amount of dielectric grease on the injector o-rings so they slide on with easy. You don't need to replace the intake manifold gaskets if they're still in good shape. But they are cheap to replace. Same goes for the knock sensors.
That LS1howto guide really makes it easy. Like TheBlueKnight said, have yourself a few sodas or beers handy, some tunes and have fun with it.
Old Jul 25, 2011 | 12:23 PM
Russell PTA's Avatar
i have an 02, so i already have the ls6 intake. do i need to chisel mine?
edit: sorry not trying to thread jack :S
Old Jul 25, 2011 | 01:10 PM
99 Blue Bird's Avatar
what do you mean? if the intake is already on your car why would you have to chisel it to fit?
Old Jul 25, 2011 | 01:20 PM
LS6427's Avatar
One trick that helps GREATLY that is not talked about in that link.....when you put the intake back on they say to put the 4 back bolts in, then HOLD them all UP as you put the intake into place. YEA, RIGHT.
Put those 4 back bolts in, lift them up so they are not sticking out of the bottom at all, make them even on the bottom. Just before they stick out. Then take a 2 inch long piece of masking tape and tape each of the bolts in place on the top.
Then you can effortlessly slide the intake into place, then down into position. Then one at a time...take the tape off each bolt and drop it into place and thread them in by hand at first. Then you can drop all the other bolts in and tighten them all down.
Old Jul 25, 2011 | 05:26 PM
ok that answered it. i thought the chiseling was helping the performance out somehow.
Old Jul 25, 2011 | 05:49 PM
BirdsSince16's Avatar
Iirc, the chiseling is to accommodate the oil coolant lines of the LS1 system.
Old Jul 25, 2011 | 06:57 PM
I would strongly suggest changing the intake manifold gaskets as they are a "crush" style gasket. When you do the install you will see that the head side of the old gaskets will be almost completely flat. Lots of guys skimp on the $20 for new gaskets and end up with a vacuum leak they cannot identify.
That's a great suggestion. To the OP, if you don't have any tape handy, rubber bands or zip ties work great as well.
Old Jul 25, 2011 | 07:19 PM
R6cowboy's Avatar
No kidding. I bought a supposably slightly used LS6 intake and the gaskets surely looked ok to reuse. They weren't flat, not like the old ones on my stock LS1 intake, those were a hell-no-way to reuse. Well thanks man, lesson learned. Thank goodness its easy and only takes about an hour to change them out.
Old Jul 25, 2011 | 07:22 PM
BashamWS6's Avatar
Banned Scammer
thats whats wrong with my LS1 intake...or it might be cracked....we will find out
alright guys i really appriciate it. sunday i will be doing the swap so incase i get doubtfouded.. i will be on here asking away
Where can i buy gaskets?
WS6store has them for $60... but fml i only paid 300 for the intake...
im calling the local chevy dealer tomorrow to check
Old Jul 25, 2011 | 07:26 PM
I got some Fel-Pros for $20ish from Advance Auto... Local GM dealer wanted like $70 for a set.
Old Jul 25, 2011 | 07:27 PM
BashamWS6's Avatar
Banned Scammer
did you have to order or did they have them at the store?
