How does this setup sound to you?
The difference between 323s and 273s is you don't have the 3rd gear 90mph lag. If I had a car with 273s I would get a used M6 342 rear and swap it in.
I have had 273s, 323s, 373s, 410s. From stock to H/C major weight reduction.
I never said anything about 323s-342s.
You can't race a car with basically the same mods and contribute the win to gears, period.
I never once said they would perform better.... I did however say that 373s perform so marginally, if any, better than 323s that the swap is not worth the trade offs.
I have done my research and seen time slip after time slip backing me, have you?
Gear swap believers are gear swap believers... You don't want to hear it because it **FEELS** like it helped the performance of your car a lot. I'm done.
2. Have you ever been to the track? Judging from your previous posts, you will be the type to stage with your rear wheels. Then when the starter backs you up, you will leave the car in reverse.
3. If your dad has to make the decisions about what happens to your car, then you are clearly not responsible enough to drive it, Or he is the one paying for everything....(equaly as bad)
.....just sayin'
I'm not as skilled as most of the guys here, but look at it this way, your car is nothing more than the sum of parts. A rebuilt 4L60E is what.. $1200 tops? If you go drag racing and you do it enough you WILL break something eventually.
A stall converter is a good budget start to getting good performance out of a car. The converter will NOT burden your tranny, but yes.. can build up heat.
Your dad is probably concerned that he'll have to fit the bill WHEN that 60 fails. At 107k miles, it's not exactly brand new, and with drag racing abuse, if you do any sort of power braking with it.. that's just gonna make it worse.
It is NEVER a question of IF a transmission will fail but WHEN.
So get the stall, get a tranny cooler, and so long as your tranny doesn't spit metal shavings into the fluid and contaminate both of them, you can re-use them on your new 60 when it goes out.
Low 12s isn't so easy without a H/C/I combo. You're doing good on yourself getting an ls6 intake, you're doing well on the headers, the stall is the next logical step if you're not ready for engine internals.
Also.. just personal opinion here.. a quick fix for that 2.73 you probably have would be to surf the classifieds.. find a guy with an m6 ditching his 10 bolt. It wont be any more reliable, but you can pick up a 3.42 for like $100. Upgraded rearend+stall+your current setup, may not get you LOW 12s, but you might be sitting at the "12 second club" table. Remember 12.99 is still "in the 12s"
LTs Xpipe dumps (or LTs ORY with a good merge cutout)
4000 converter
ls6 intake
tires
tune
3000+DA or better and you should hit bottom 12s. Regardless if car has 273s or 323s.
OP- Is this a drag car or a DD? Two totally different builds. If it is a drag car, ditch the 4l60e all together and get a built 350 or 400.
Just be careful out there.. insurance is high enough on Fbody cars already.
Car b- stock with a converter
Car a gets drug extremely hard. Gears are such a minimal gain for autos its not worth it. Converter is the mod for autos, period.
There are plenty of 323 cars put there that would drag your 373 car, trust me.
You done any research on this or just babbling?
Who is this guy in KC that's doing the PCM rework? Is he a tuner experienced with these cars and engines? If he's not, he's gonna make it worse for you.
Your other mods add virtually nothing. You're not doing the stall converter now and the 3.23 rear will only make you slightly quicker than 2.73's. Do you even have a shift kit in this transmission? Without it, it'll slip as designed and hurt your times.
Did we mention the sloppy stock suspension and engine mounts will also hurt your times as everything is gonna wind up and shift around?
When are you going to the track? I estimate 13.4 to 14 second quarter mile times. You have too many things working against you.
You opened this thread not knowing what the panhard rod is. But you are so confidant you'll do mid 12's?
You say you don't see why you can't achieve mid 12's? Why does everybody else here see why you won't achieve mid 12's?
I don't know how old you are myfirst01, but if your dad holds the wallet in the decision making I'd guess 16/17. At your age I knew far less about all of this than you do now.
I think it's great you have enthusiasm and a goal in mind. If you don't have a long driving history, a car in the low 12s may not be the best way to start off anyway.. better on you to start with a semi-stock car like you have now, run it at the dragstrip, get your launch/staging and all down and get the "noob" worn off (I've never ran at a strip so I'd be a total joke..
I think you're in a good situation right now personally. You may be disappointed that you haven't met that goal.. but doing the work and learning on the way is FAR more valuable than bragging rights.
When I was 13 my dad got a 65 chevelle that was burning oil real bad and running on 4 or 5 cylinders. We spent months working on it in the driveway and eventually wound up pulling it and having the long block rebuilt. The things I learned from that experience are more valuable than anything I would have had from cruising around in a fully restored chevelle that my dad bought or something..
This is what hot rodding is about! It can be frustrating yea.. (believe me
Good, the tuner knows what he's doing.
It's too bad you're stifled by what your dad says but as a parent, he's looking out for your safety and to keep your car from blowing up. DarkFox is right, a 12.5 car is not for an inexperienced new driver. In due time, you'll be able to do your own thing. You'll get there. In the meantime, search and learn, search and learn.
