How does this setup sound to you?
https://ls1tech.com/forums/automatic...ns-cooler.html
http://www.holley.com/types/Temp-A-C...%20Coolers.asp
Also, how far are you willing to go as your drag / street/strip setup?
NO, do not install a poly transmission mount with stock motor mounts.
YES, the Yank cooler will do fine for you.
You’re really only scratching the surface to make your car “fast”. Getting a stall converter will help and as stated here a few times by a few guys, it won’t “tear up” your transmission so long as you have a proper cooler.
As you start to add power, you’ll need to start considering other things. The stock suspension and torque arm will only work for you up to a point. Are you aware that the 10 bolt 7.5 inch rear WILL break in due time?
Adding a torque converter, lid and exhaust will help but not as much as you think.
Listen to, pay attention to and trust those here who've done every possible trick to these cars. They know what works and what doesn't.
When you make the move to a stall converter, it should go without saying that as you're obviously going to race this car, your transmission needs to be in good condition, How many miles on it? Has it been beaten on? Over heated? Burned fluid?
As the engine moves around, so does the transmission, especially at WOT at the track. A poly transmission mount is almost a solid mount. As the engine tries to move around, the transmission will resist the movement. Don't forget the torque arm is carried by the transmission tail housing.
Doing so you risk breaking the transmission tail housing.
If you intend on getting poly engine mounts, then yes, get a poly transmission mount.
If you get new stock style rubber motor mounts, you'll need to stay with a stock style rubber transmission mount.
but i will have to pass on the one you have for sale. thanks tho
