Edelbrock Pro-Flo XT LS1 EFI Intake Manifold
Old 08-16-2011, 07:11 PM
Grn4fbody's Avatar
Default Edelbrock Pro-Flo XT LS1 EFI Intake Manifold
Anyone have or tested one of these? I did a quick search and haven't seen anything on it.
Old 11-26-2011, 11:32 AM
HottLS1Z's Avatar
Also wondering about this. This thread is what my search results yielded
Old 11-26-2011, 12:17 PM
Tzion_ben_Arthur's Avatar
This thread changed my mind on the intake, but it appeares that the opinions vary. I hope this helps.
https://ls1tech.com/forums/generatio...xt-f-body.html
Old 11-26-2011, 12:41 PM
Ronny_02_WS6's Avatar
It will not fit, you have to do modifications to the car.
Old 11-27-2011, 07:06 PM
fastsspr's Avatar
Is any one here that did a comparison between this intake and the fast 90/90 or 102/102 ?
Old 02-07-2012, 12:18 AM
fastsspr's Avatar
still no data on this intake?
Old 02-07-2012, 12:49 AM
Blk98Vert's Avatar
It gains above 5500 rpm and loses big below that on a NA app. So for anything less than a racecar a fast will do better. On a boosted app its among the best choices.
Old 02-07-2012, 12:58 AM
What about the Holley Hi-Ram, is that one only for LS3?
Old 02-07-2012, 01:04 AM
Blk98Vert's Avatar
Yes, it is LS3/L92 ports only.
Old 02-10-2012, 05:47 PM
fastsspr's Avatar
No one else make test with it on NA cars?
Old 02-10-2012, 09:08 PM
Blk98Vert's Avatar
It's been done, it acts like its designed to, it is a budget sheetmetal intake. It's great for NA cars that live above 5000 or turbo cars but other than that I wouldnt run it
Old 05-02-2012, 12:50 PM
68LS1WANNABE's Avatar
Does this intake work better on a larger cubed motor. How bout a cammed LQ9. Seems to be a great intake for boosted motors.
Old 05-18-2012, 10:48 AM
fastsspr's Avatar
To my judgement they are only a few people that did a fair test. But that is not enoth data to take fair desition on this intake!
I think like you. For boost i think is pefect !
Old 05-18-2012, 11:15 AM
noonzor's Avatar
Im looking to order this intake for a boosted 370 build, could i get away with using the stock tb or should i invest in an aftermarket 85/90?
Old 05-18-2012, 09:31 PM
fastsspr's Avatar
if you keed the stock tb it going to be a bottle neck and you not going to use the full potential of the intake go with a bigger TB like 85 or 90. In the near future i think i going to buy one too.
Old 05-18-2012, 10:17 PM
Blk98Vert's Avatar
I take back my prior statements about the intake and will be running one soon
Old 05-19-2012, 09:35 AM
jzingre's Avatar
holley hi ram is about to release for ls1/ls2 cathedral port heads... believe its part # 300-123... Worth a look, but requires wiper, cowl, and hood mods.
Old 05-19-2012, 10:13 AM
SweetS10V8's Avatar
Ive done the testing personally on an engine dyno, and this is 100% correct.
Doesnt make much sense, you were right......
Old 05-19-2012, 10:21 AM
Cosmos's Avatar
I have this intake and will have the install finished today. I have to run the stock TB for now but thats okay. Tests I've seen have been great! You need the correct set up for this intake. Heads,cam and all that stuff.
No offense sweet, but it gets old that you come in and **** on intakes that don't have the FAST logo on them. You say you have results but never back them up.
I will have results hopefully in a few weeks.
Old 05-19-2012, 10:59 AM
SweetS10V8's Avatar
Incorrect, Im all about the right manifold for the right application. It just happens the LS6 or FAST is the most correct for 90% of people, depending on budget.
If you go drag racing often, and very little street time, so you spend a substancial part of your engines life in the higher RPM range....The Pro-Flow, Holley HiRam, and all the other short runner intakes manifolds are more optimal and will make 10hp,or so, @6500RPM+ over even the FAST, but at the cost of low RPM torque and drivability.
You dont have to post a dyno graph to share your experiences.......
