30lb injectors w/ bolt-on's
Old Oct 22, 2011 | 04:54 PM
arock24's Avatar
Default 30lb injectors w/ bolt-on's
I was messing around on ebay and got a steal on a set of 30lb injectors. Would it be better off just to sell them, or would it benefit me to throw them on when I get my dyno tune? (adding 3600 stall and underdrive pulley)
Old Oct 22, 2011 | 05:21 PM
bene's Avatar
Trunion King
That set isn't going to benefit your car at all being your stock ones are more than enough for bolt ons.
Old Oct 22, 2011 | 05:27 PM
trans_am7935's Avatar
i have seen people use stock 28lb ones for cammed cars all the time making more then 400rwhp, sell them dont waste your time.
Old Oct 22, 2011 | 05:32 PM
arock24's Avatar
That's what I thought, only spent $70 on the set, figured I could at least make a little money if anything.
Old Oct 22, 2011 | 05:49 PM
sell them to a mustang guy for $200. easy money
Old Oct 23, 2011 | 01:14 AM
When I pass the 6/50 requirement I will post them for sale here.
oh and reading your sig, ditch the shorties, get some long tubes. you will be alot happier
Old Oct 24, 2011 | 07:48 PM
arock24's Avatar
I have pretty strict emissions, didn't feel like taking the chance on failing. I've heard of tunes working and not working.
Old Oct 24, 2011 | 08:21 PM
baxsom's Avatar
what is your injector duty cycle? Bolts ons wont need them but if you do a cam swap you may need the extra fuel. Like was mentioned before people use the 28lb injectors on cam swaps and they do ok but I have also seen people post cam swaps on 28lb injectors with 100+ duty cycles. The 30lb ford injectors are really 36lbs at the LS1 fuel pressure. If you have plans on a head and cam swap later keep them. I sent a used set of 30lb injectors as cores for a brand new set of flow matched ones from fuelinjectorconnection and got an awesome deal.
Old Oct 26, 2011 | 04:26 PM
arock24's Avatar
H/C will be coming, but not until next summer. I'm dreading even pulling this tranny for my converter, and I've heard the pulleys can be fun as well. Keepin the project light for the winter.
Old Oct 26, 2011 | 04:37 PM
thunderstruck507's Avatar
If you are going to do heads cam you will likely need slightly larger ones. I would sell them.
