will ported TB mess up tuning?
Old Mar 20, 2004 | 12:01 PM
CrazytrainWS6's Avatar
Default will ported TB mess up tuning?
i have my car dyno tuned. if i add a ported TB will it make my car run leaner and hurt my engine?
Old Mar 20, 2004 | 12:10 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
It will alter things a bit. I've had my car tuned and have changed the exhaust setup to true duals, have put on a ported TB and things are a bit wacky at startup. Engine needs about 3-4 minutes to find itself and run correctly. After that, things are fine.
Old Mar 20, 2004 | 02:49 PM
jimmyblue's Avatar
Moderator
Maybe you're thinking the ported MAF, which is
probably the single biggest sexually transmitted
disease of the late-model F-body.
The TB is basically a piece of pipe, a ported TB
is a smoother piece of pipe, and if it doesn't leak,
it can't affect the mixture (though it could let
you intake more air at high RPMs, attaining higher
peak cylinder pressure, and letting you ping in
places you could barely get to before).
Old Mar 20, 2004 | 02:53 PM
Beast96Z's Avatar
To answer your question, the only way the TB could possibly hurt your mixture is if your dyno tune is on the verge of super lean already. The MAF will read more incoming air, therefore adding the proper fuel to make things right. You should have no problems at all.
Old Mar 20, 2004 | 02:55 PM
!LS1 11 Second Club
Some TB's are epoxy filled and alter the idle air passage slightly. When you're runnin' a big cam something like that can change things a bit. Nothing major, but it does have an impact.
Old Mar 20, 2004 | 04:04 PM
cool...thanks for the info guys. i want to order the bauer TB, but i have to find out the turn around time. does anybody have an experience/knowledge of the TR TB or the new TSP TB that is coming out?
Old Mar 20, 2004 | 07:48 PM
m6camaro's Avatar
maybe you should try a jantzer TB. Got mine in the other day powder coated red and it looked great. Very satisfied with it.
Old Mar 21, 2004 | 12:29 AM
00silverz28's Avatar
I've got the jantzer tb too powdercoated anodized blue and its a great piece. Turn around was about a week and a half.
Old Mar 21, 2004 | 02:54 AM
Blue2002SS's Avatar
I just sent mine out to Bauer about 2 months ago and it took about 10-14 days I think
Old Mar 21, 2004 | 10:11 AM
JCJohnson1510's Avatar
is a ported throttle body on a stock tune bad? read that in car craft magazine i think, i was just wondering how true that was. also, what is the difference in a jantzer or bauer and a home ported throttle body?
Old Mar 21, 2004 | 07:48 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
Had mine done by Bauer - turnaround time was 2 weeks - he does an excellent job and I had no driveability problems after the install
Old Mar 21, 2004 | 08:02 PM
Jammer's Avatar
I have the bauer and it tokk a few miles, but than ran great. Its for sale w/ an intake in the FS section....
Old Mar 22, 2004 | 04:05 PM
mike c.'s Avatar
crazytrainws6-i just got my t-body back from bauer. it's a work of art. it took about three weeks to get it back,i put it on and fired it up.
Old Mar 22, 2004 | 05:52 PM
again, thanks for all the replies. i got my response back from the email i sent bauer and he said normally 5-10 days which is outstanding. so after im done typing this, im taking the TB off and getting it ready to be shipped off.
