If SLP made the 2OTL again, would you buy it?????
#41
I'd love to have a 2OTL Setup and I don't even have a 4th Gen Camaro. I suppose one of these would look alright on a Firebird Formula, but its not something I would do to any of mine. Although, if they were priced right, I would definitely buy a kit just to have in the Inventory.
#45
I took my 21 inch long Stainless Works muffler and stuck under the car, don't thing it will work.
The length will work, the width is the problem.
Because the truck muffler has an offset inlet it will put the muffler closer to the panhard rod, the only way to move it further to the rear is to slide the I pipe back closer to the axle housing to move the muffler closer to the rear.
It might work but it would be a PITA to make it fit and not rattle. Might STILL be worth it.
#46
Pics?
you can put the offset inlet, front or back? you can get a reloc PBR and brace. Or remve the PHR brace all together. I didnt run mine for a few years. I know have a TRZ ARB so I have alot more room getting pipeing over the rear end. My PHR is behind the old spot so I lost a little room, but should have enough to fit a wider muffler.
#48
Love mine =)
Also, its CONSIDERABLY louder than my old Dual/Dual, both sound great!
I got mine as a full catback for $175, think I did pretty good =)
I'll probably try to keep this exhaust, even if I sell the car, looks good and its unique.
People think my car is a 6 all the time =P
No badges, body colored hardtop, single exhaust =D its fun!
I'm pretty sure I have a buddy thats hoarding at least 2 of these exhausts lol.
#54
I love it, manageable inside the car when cruising, sounds like a Nextel Cup Car when the pedal is down!
Silencer was out, tailpipes were perfect. The guy cut the over the axle pipe to get it off....you can see where he was beating on the muffler trying to get it off it has two small dents on the end but it's not bad. Had the pipe welded and put it on.
Got it for $380 shipped
#55
Love mine =)
What size tire on the rear?
Please paint your t top well black.
#57
