Cutout size, exhaust question, supporting mods questions
I am about to place orders for 1 7/8 TSP headers, 3" TSP ORY, Magnaflow Catback, obviously O2 extensions and new gaskets with that.
Then poly motor mounts, SLP Lid, I have an LS6 intake manifold on the way, UMI weld in SFCs.
Wanting a DMH Cutout, so would that just be a 3" size that would go in right after the Y, correct?
Getting a Shaner S2 Throttle body, as I saw it highly recommended on here.
Moser axles and 3.73 gears in my 10 bolt. Don't want much input about this, just telling you what I am doing. I have heard the whole thing about the weak 10 bolt, upgrade immediately, blah blah, I will test my luck for the moment.
Edit: Also thinking about plugs and wires from Texas Speed, which set would you guys recommend? MSD Plug Wires and NGK TR-6 Spark plug combo or MSD Plug Wires and NGK TR-55 Spark Plug Combo?
--Questions, if anyone can put in their .02--
1) How much power will this exhaust setup be good "up to"? I suppose before its too restrictive and what not. Thats with headers/ORY/Catback/Cutout
2) I know before I get into serious power, I will work on the suspension to be able to put down the power, so I dont need to hear people give me that input.
3) Back to combining 1 & 2, what would people's recommendations for the future of making more power. I have a rough idea where the mods I am doing will put me, maybe at a 13.0? Sound right? But my goal for the car is to be a car that can be driven on the street, not going to be a daily, but want it to be fairly tame on the street. I also plan on taking it to the track every once and a while (this is where I will eventually upgrade to that 12 bolt). I dont know how much power or what I should look into to make the power, to maybe be in the mid 11s and not be breaking stuff all the time.
Anyways, any input on setups and recommendations would be great. Right now I am obviously just getting the platform of boltons set and want to make sure I am making a platform that I can USE for down the road when I want to go faster.
Thank ya!
Thank ya!
When it says "E cutout with flowtech", what exactly is the Flowtech? I think I may be just not putting 2 and 2 together lol
Edit: And what would be the "approximate length of cable needed"? That I have to enter in on the page to place the order.
TSP's Y-pipe actually has a 3.5" collector and then it necks down to 3". If I were you I'd cut off the reducer part, weld a 3.5" cut out on, and then weld the reducer back on to connect to the cat back.
Ah gotcha. So what have people done for installing the 3" or 3.5" cutout before the catback if the y pip --> catback "connection" is 2.5" or 2.75"? Cut the ORY end and add in pipe to fit?
