TSP ORY fitment issues
Old Sep 27, 2012 | 04:37 PM
dalejrfan88's Avatar
Default TSP ORY fitment issues
Hey guys so this past weekend i finally got around to installing my 1 7/8 TSP headers and ORY. The headers went on great! The y pipe absolutely sucks though. Not only does it not bolt up to my borla catback ( a few inches too long) but it also will not come close to clearing my spohn tunnel mount torque arm and driveshaft loop. Its the one designed for longtubes. I already cut a small section out of the catback hoping to fix the problem but to no avail. Is there a better fitting y pipe out there that will fit my t/a? Has anyone sectioned out a few inches of theirs to make the tunnel mount fit? Any help will be greatly appreciated since I've worked on it all weekend and its still not right.
Old Sep 27, 2012 | 09:11 PM
Violatorno1's Avatar
This is something of great interest to me also since I was just planning to purchase the TSP y-pipe now and the 1 7/8 headers in about a month. Seeing as I also am running the Borla cat-back I'd like to know if anyone has had these issues and what they did to remedy them. Guess I'll put the y-pipe on hold for now.
Old Sep 27, 2012 | 09:25 PM
Sales1@Texas-speed's Avatar
With so many different combinations out there its hard to make a one size fits all part. I have installed several of our y-pipes without a problem. One of those cars was mine that I tested fitted to see how clearance worked with the Midwest Chassis torque arm setup with drive shaft saftey loop and it fit great. I apologize your having some issues, and we did our best to offer a ypipe that will work for everyone, but like I said with so many different setups out there its almost impossible to guarantee perfect fitment with every combo. Send me a message over with any other questions or concerns you have. Im happy to help.
Old Sep 28, 2012 | 06:52 PM
14k's Avatar
14k
You could help by posting a pic of your personally cars ypipe clearance from the drivers side
Old Sep 29, 2012 | 07:03 AM
I ended up just modifying the I pipe and realizing that i will need to get a full length torque arm instead of using my current one.
Old Sep 29, 2012 | 10:54 AM
Unfortunately the pictures I posted up a while back are the only ones I have, my car is back apart for the boost build, so I did away with previous exhaust setup.
Old Sep 29, 2012 | 12:13 PM
My current setup is the same as yours. I am using the Borla 3in cat back plate system, Jet-Hot LT's and a Spohn chassis mounted TA with loop designed for LT's. I went with the Hooker 3in off-road y-pipe back when I was modding my car and had no fitment or clearance issues with the Hooker Y. Downfall is that the Hooker doesn't have the nice merge but should work with the TSP headers. Just a thought.
Old Sep 29, 2012 | 12:20 PM
Aaron,
Can you recall installing your y-pipe on any Spohn chassis mount TA equipped cars with no issues? Maybe there is a problem with the pipe itself that went unnoticed.
Old Sep 29, 2012 | 12:22 PM
Ill be honest I have not installed one with a Spohn setup.
Old Sep 29, 2012 | 12:26 PM
You're not helping me get my TSP y-pipe and I really want it to fit and work.....lol
Old Sep 29, 2012 | 12:29 PM
I know man. Yea I just never have had the opportunity to work on an F-body with the Spohn setup. Also you wouldn't think there would be a ton of difference between all the setups but every vendor builds their torque arms setups a little different, which in this case cut down on clearance for us a bit it seems.
Old Sep 29, 2012 | 05:34 PM
sepsis's Avatar
My TSP Y didn't fit perfectly either, but that's what a good exhaust guy is for.
Instead of blaming the part, maybe you should have a professional try to install it first.
TSP makes a great Y pipe and merge.
Old Sep 29, 2012 | 07:07 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Damned right they do. I remember doing the cigarette test when I had mine. Placed a lit cig in front of one leg of the Y, and blew a bit (not a lot of pressure) of compresssed air in the other and it scavenged QUITE well.
sepsis hit the nail on the head needing a good exhaust guy. Spend the extra 50 bucks if needed and get it on a lift, fit, and tucked. Bottom line is you very well may need to cut about 2 or 3" of the I-Pipe to get it to fit. I did and that was with a Magnamouth.
Old Sep 29, 2012 | 07:25 PM
I think I'm going for it anyway. After studying the pics of it hard I think I can make it work. I don't mind cutting things down, I just don't want to have to mess with the bends. Every shop in this area, including ours, have benders that tend to screw up the bends of stainless. As for install and adjustments, I have that covered....lol
Old Sep 29, 2012 | 08:07 PM
dr_whigham's Avatar
The Scammer Hammer
Hopefully this help you. This is from when I did mine last year.
Old Oct 15, 2012 | 05:48 PM
skidooingit's Avatar
i just installed a TSP 3 inch chrome ory to a set of kooks longtubes and a TSP rumbler catback with the midwest chassis torque arm setup with the built in loop and i had to notch the bracket on the loop for the y to fit. its a really tight fit.. but seems to tuck good... maybe to good it touches the floor pan almost. I also have new poly trans and motor mounts. I think the ORY is a nice piece for the price... and i would say that every setup is going to be a bit different on every car so taking your time with fitment and being prepared to have to do a bit of cutting notching modifying is going to be part of any full exhaust system. If your not skilled in the exhaust department it might be a better job for a good exhaust guy
Old Apr 17, 2013 | 11:20 AM
LS1Adam84's Avatar
I had an issue with it not tucking up well on the driver side, I messed with it for a while and the best I could get was still not good, I scrape on most bumps, I will be pulling it off and I bought some exhaust tubing to put in place and see about tucking it up some more.
Otherwise I say best ypipe out there, the merge is damn nice and less rasp than other ypipe setups, I have the magnaflow catback and had to cut a little off the Ipipe, but that's the beauty of working on cars, each one has it's own unique "quirks"...
Old Apr 19, 2013 | 05:27 AM
Slowbird780's Avatar
I just did this last weekend. I have tsp 1 7/8 longtubes and a borla catback and I went with the tsp off rd y. The ypipe fitment was not good. I ended up making my own pipe off the driverside header and after that it was fine. I also had to chop down my borla "I" pipe about 2 inches. Hope this helps.
Old Apr 19, 2013 | 07:49 AM
blackbird0230's Avatar
Hahahaha I did that same ****!!! Three years ago I bought tsp LT's and ory with manaflow catback and a spohn tunnel brace. **** that y pipe. The headers fine, but that y pipe went to the trash and I got custom true duals. Read up on the y pipe. It's ****. I cut up my I pipe also to make it work and left the brace off. Now my catback is worthless too since it don't fit nothing.
Old Apr 20, 2013 | 09:37 PM
Uneverknow's Avatar
I have hooker headers with the tsp y pipe and I had to cut down the pipe on the drivers side header to make it fit, but after I did that it worked well. I also cut off the 2.5" exit from the merge and welded on a 3.5 to 3" transition. Hope this helps you guys
