Failed Start attempt
Old Oct 11, 2012 | 10:17 PM
smahlum_21's Avatar
Default Failed Start attempt
Well after putting in my new H/C/I and headers, I tried to start the TA tonight. It initially had power but as soon as I went to turn it over nothing. I was thinking maybe battery was bad from sitting for a few months, but had it checked and is fully charged. Im assuming I have a short somewhere, what all wires could it be. I guess my big fear was right before that put my PCM back in and hope that didnt get fried or anything, if that is even possible. Any ideas where to start would be appreciated.
Old Oct 11, 2012 | 10:43 PM
therealcreeper's Avatar
ground to back of head?
Old Oct 11, 2012 | 11:21 PM
smahlum_21's Avatar
I know I hooked up three to the back of the drivers side head. One on drivers side right below the exhaust ports and they may have been it.
Old Oct 12, 2012 | 12:46 AM
smahlum_21's Avatar
Two wires to starter seem fine. Ground wire from batter to passenger side wheel well, ground behind alternator and ground by fuse box are all ok. Am I missing any??
Old Oct 12, 2012 | 12:57 AM
smahlum_21's Avatar
Also should have mentioned its a 99 TA. Is there a ground that goes on passenger side of block as well?
Old Oct 15, 2012 | 03:46 AM
smahlum_21's Avatar
Anyone?
Old Oct 16, 2012 | 08:01 PM
moeZ28's Avatar
Back of the driver side head has two wires, but 3 eyelets for grounds. Car will crank but never fire if all 3 arent grounded.
Old Oct 16, 2012 | 08:02 PM
moeZ28's Avatar
Just saw where you said you did connect all 3 on the back of the driver head...does the car crank at all or just dead?
Old Oct 16, 2012 | 08:20 PM
smahlum_21's Avatar
I put the battery back in today, and made sure I had the cables connected to it tight using a socket. Started right up, so maybe didnt have it tight enough. Also cleaned up the positive side some maybe that did it too. Now problem is my tach isn't working anymore
